K's J3?
Re: K's J3?
So how did you overcome the difference in size of the oval cutouts in the tender side frame?
Re: K's J3?
Now I think about it again I need to make a correction. The 4700 gal frame was a cut and shut. The GN frame profile was cut out by hand and then had resin copy axleboxes added.
Re: K's J3?
While I don't hold a torch for K's, I truly doubt that they made a regular practise of renewing the moulds from castings off a previous mould: why would you, when in possession of the patterns from which the first set of moulds were made? Doesn't rule out some occasional 'desperation city' job when an original pattern had been significantly damaged or somehow lost.
A broadly applicable truth to many of the whitemetal kits in the days of yore. The frequently proposed and well meant advice to 'obtain a good drawing', just opened a new can of worms.john coffin wrote: ↑Thu Mar 18, 2021 11:40 am ... a drawing will only confuse even more, since you will find it difficult to reconcile the various differences...
Re: K's J3?
If use of existing casting didn't occur how do you explain the distorted domes and chimneys etc. Moulds from original masters wouldn't have produced these results. I was told this was happening many years ago by someone in the know.Hatfield Shed wrote: ↑Sat Mar 20, 2021 11:28 amWhile I don't hold a torch for K's, I truly doubt that they made a regular practise of renewing the moulds from castings off a previous mould: why would you, when in possession of the patterns from which the first set of moulds were made? Doesn't rule out some occasional 'desperation city' job when an original pattern had been significantly damaged or somehow lost.
Re: K's J3?
I wouldn't for a moment deny it happened, there was some very duff output from K's. Thus my earlier posting:
Hatfield Shed wrote: ↑Sat Mar 20, 2021 11:28 am While I don't hold a torch for K's, I truly doubt that they made a regular practise of renewing the moulds from castings off a previous mould: why would you, when in possession of the patterns from which the first set of moulds were made? Doesn't rule out some occasional 'desperation city' job when an original pattern had been significantly damaged or somehow lost.
Re: K's J3?
Funny you should be talking about the K's J3, I've been 'Playing' with a J3 chassis for the last couple of days, new scale wheels, new motor, and picks ups and I can't get the darn thing to run, it even bent the (k's)coupling rods, coming to the conclusion the axle holes are wonky. This chassis is suppose to be for the J7.
Re: K's J3?
Manna,
If you have the type of K's axles with the 10BA fixing you can screw Romford crank pins into the ends. As the crank pins will slip into the coupling rod holes you can easily compare the chassis and coupling rods. I hope my explanation is clear.
Re: K's J3?
I'm using Hornby sized Romford axles ( big axle) and Scale Link driving wheels, I can't post a picture as I've just changed computers and it won't let me make my pictures smaller, 3.5 meg is far to big. The scale Link drivers are like Romfords but have a plastic center.
Re: K's J3?
Right,
Place the chassis over a piece of card but raised a couple of mm. Push the axles through the chassis and tap the ends lightly with a soft mallet. You now have three indentations over which you can place the coupling rod/rods.
Re: K's J3?
Now I know where your going, will let you know.
