Re: Atlantic's works: Ore hoppers cont'd, P2 chassis mods st
Not all that clever, surely?
Anyway, this one is now sporting a bit of bling in the form of a nice shiny reversing rod filed up from surplus coupling rods on a partly used etch: While that one continues to ferment slowly I've started a second brew to keep it company: That's a chunk of GBL Mallard at the front, cut a little way aft of the first boiler band to give the correct length for the P2. The Upper slope of the smokebox front has been filed back to give a longer rake, so the chimney "which has also been moved forward a touch) will need restyling to include a longer rear fairing in order to fit. The new black sections of boiler are from pre-curved 20 thou plastic, in three layers. While I was cutting away the top section and re-making it, I thought it would be far less work compared to the filing and scraping on Earl Marischal if I simply cut out the ACFI bulge entirely and re-made that area of the boiler too.
For those who like to scrutinise more closely.... Not even a hint of filing of the front of the chassis weight has been needed so far.
You could produce the streamlined P2 as 2005 Thane of Fife with a small chimney.
One certainly could, although mine is destined to be another Lord President. Having built the A2/2 version it only seems right and proper to show how it should have been.
The speed & efficiency of your work never fails to amaze me!
Great stuff
Great stuff
Will
viewtopic.php?f=3&t=9293
My Blog
My Blog
Having frequently been impressed, not to say daunted, by your semi-finished and finished product, that close-up of the early-stage "Lord President" cheered me up no end -- even GK's work can look a bit untidy at this stage in the proceedings. That's not a criticism, by the way -- its a "thank you" for lending some heart to a neophyte. (Not that I shall be taking a scalpel to a P2 in the foreseeable future....).
auldreekie
auldreekie
Glad you have found encouragement. You should have seen it an hour before I took the picture, when I'd decided that there was an unwanted bulge in the surface layer of plastic and had ripped same off the model ready for trimming, smoothing and re-application!
Graeme - I have cast several resin copies of my white metal P2 streamlined chimney if that would be of interest? Happy to donate one to the cause.
I do like your conversions very much and I'm delighted to see a bugatti nosed variant join the Earl.
- 2002EarlMarischal
Most impressive and made to look so simple as always!
The chimney sounds a good offer Simon. Yes please! It will be interesting to see how it fits, how it looks and how it compares to drawings.
In which case I will get the mould out tomorrow night and will cast you a couple to send - I think your address is the same as previous so I'll try to pop them in the post on Saturday. From what I can see, they match up to the Isinglass drawings reasonably well.Atlantic 3279 wrote:The chimney sounds a good offer Simon. Yes please! It will be interesting to see how it fits, how it looks and how it compares to drawings.
Tidier now:
Now, I wonder where that nose has come from?
Gives me an idea!
Gives me an idea!
Who nose...................Blink Bonny wrote:Ay up!
- NBR J36 0-6-0
Another splendid conversion on the cards. It does beg the question, how did Thompson get authority from the LNER board or the Railway Executive to rebuild them?
Paul 4475
Paul 4475
Much writing and discussion on this. Major arguments seem to have been that failures on the road were increasingly problematic in wartime conditions. This also seems to have been one reason why ET was not in favour of transferring them south. (Although it wouldn't have been his decision would it?)Flying Fox 34F wrote:Another splendid conversion on the cards. It does beg the question, how did Thompson get authority from the LNER board or the Railway Executive to rebuild them?
Paul 4475
A broken crank axle at one of the ECML bottlenecks would have been very bothersome, but perhaps with Doncaster maintenance rather than Cowlairs that wouldn't have happened.)
(Just to make my views quite clear - I think the decision to re-build was not one of ET's better ones!)
I do like the story (I think in one of Peter Townend's books) of the Shedmaster at Haymarket sending P2s south to Newcastle at night 'when no one could see'!!!!!
They could pull anything up Cockburnspath when a Pacific would have had to be double-headed.
I'm following this and the other P2 threads with interest. I do so want a Bugatti-nosed, double Kylchap, P2 in green. Do you suppose any of them got into County Durham in that condition?
