Let me know about the tender you wanted.S.A.C. Martin wrote:Thanks Ivan - exactly the same as an actual A2 more or less if you remove the lugs. I reckon that would do nicely on a model I've been working on.
Great British Locomotives Magazine
Re: Great British Locomotives Magazine
PM sent.Horsetan wrote:Let me know about the tender you wanted.S.A.C. Martin wrote:Thanks Ivan - exactly the same as an actual A2 more or less if you remove the lugs. I reckon that would do nicely on a model I've been working on.
...and replied to.S.A.C. Martin wrote:PM sent.
- Saint Johnstoun
Does anybody have actual confirmation at what number the series will finish?
Nope.
...but I'm only after one more, and that's the Class 47 / Brush Type 4 diesel.
Saltash?Kestrel wrote:Does anyone know where this is??
http://greatbritishlocomotive.co.uk/_uk ... -cover.jpg
Had our fellow contributor been a little more forthcoming with information or rumour from the Western Front, with which he is thoroughly familiar, he might have provided the following note of what are said to be the final three issues:Saint Johnstoun wrote:Does anybody have actual confirmation at what number the series will finish?
39 August 5th A1/A2
40 August 19th Brush Type 4
41 September 2nd Locomotion No 1(perhaps)
Based on the potential inaccuracy of this information, maybe he didn't want it to be seen to come from the horse's mouth......
Vicious rumours, Graeme. Vicious rumours.Atlantic 3279 wrote:....maybe he didn't want it to be seen to come from the horse's mouth......
To be pedantic (well I am!) it's actually St Budeaux, the Devon side of the Tamar, looking towards the Tamar bridges with Saltash in the background.52D wrote:Saltash?Kestrel wrote:Does anyone know where this is??
Alan
Excellent. Simon's taking the A2 tender, and someone else is relieving me of the cosmetic track base. Means I can keep the engine body and the screws.
Anybody in the Grantham area looking for the A2, Sainsbury's had two left on the stand by the entrance/exit this afternoon
Re: GBL A2
It's not just on the right hand side. The incorrect transition also occurs on the left - though partly hidden by the LHS ejector pipe. In summary, the transition occurs too low down, which then makes the (lower) firebox too narrow.Hatfield Shed wrote:....the awkward transition from round to flat on the RHS firebox side are easily dealt with. ....
I'm just trying to work out where to saw off and reposition the flat sections. Some plastic filling will be needed but since all the moulded detail is to be shaved off, at least the task is made a bit easier.
If the whole thing is too narrow and you plan to lose the surface detail anyway, then why bother cutting the original sides off? You could just add a suitable extra layer over them and blend the top edge into the curve in right place, preserving full strength of the original moulding.
Hmmmm......Atlantic 3279 wrote:....why bother cutting the original sides off? You could just add a suitable extra layer over them and blend the top edge into the curve in right place, preserving full strength of the original moulding.
