Saint Johnstoun
Re: 2002's 4mm projects - Pacifics +
Post by Saint Johnstoun »
That's exactly how I got my 60100 Spearmint plus doing a tender swap. A bit of ingenuity will get you what you want.
2002EarlMarischal
Post by 2002EarlMarischal »
That's a very nice result Allan. :)
I am hoping that the ease of removal of the American paraphernalia is the point I am trying to illustrate for others who may be reluctant. Just because Hornby has at least temporarily let us down, doesn't mean we can't have LNER liveried A3s if we want them!
Right now there is a USA Scotsman set minus observation car for sale on eBay at £84.99 + £5.25 postage. I bought 2 from the same dealer who waived the postage charges, then I sold the 2 water tenders for £52 and £48 respectively on eBay. After eBay and Paypal fees I ended up with 2 A3s each costing around £40 - cheap as chips! :D
Saint Johnstoun
Or of course you can do as I did and modify the Scotsman tender to get it correct for the 1928-35 period.
If you are clever you can also remove the 'dome' and replace with an alternative!
2002EarlMarischal
Saint Johnstoun wrote:Or of course you can do as I did and modify the Scotsman tender to get it correct for the 1928-35 period.
How did you find removal of the banjo dome and replacement further forward with a round dome? (Filling, colour matching etc?).
Saint Johnstoun
If you are very careful the banjo dome will come off without leaving any marks and then one can replace it with a round one in the right place. The boiler band lining appears to have been put on before the dome is affixed so if any touching in is required I find that Precision P751 is the best match.
nigeln
Post by nigeln »
Saint Johnstoun wrote:I think what 2002 means is that the loco has nearly 5' overhang at each end from centre of front bogie wheel to buffer tips and likewise from centre of rear tender wheels to buffer tips.
The drawing shows 4'1 1/2" at the front and 5'6 1/2" at the rear!
looking at cock o the north on the Kings Cross turntable it seems quite a good fit and easy to turn
or the men pushing and pulling were arnie`s grandparents :lol:
Nigel.
If it fits in the door it stays
nigeln
Re: Time to turn some ideas into reality!
Post by nigeln »
2002EarlMarischal wrote:Here is a shot of progress to date on the Empire Exhibition Scotsman. I've tried to represent the brightwork in a manner consistent with that already done by Hornby on the donor loco, and I have a little touching up to do where my hands weren't steady enough. The Fox supplied nameplates, maker's plates and LNER coat of arms have been applied.
The attachment IMG_7396.JPG is no longer available
I'm still waiting for the right tender to pop up, and I need to check out the availability of The words "SLEEPING CARRIAGE" rather than "sleeping car" which currently adorn the side of Hornby coach I'm using.
I'm hunting for photos of the exhibition stand itself taken from different angles so I can create a realistic base.
Found this photo of flying scotsman if it`s any use ?????
Nigel.
nigeln
Post by nigeln »
OOPS sorry wrong one :lol: :lol: :lol: :lol: :lol: :lol: :lol:
Nigel.
2002EarlMarischal
Thanks for the photos nigeln! :D
Post by 60800 »
It seems even back then they thought they could remove the connecting rods for long moves to exhibitions and no-one would notice :roll:
I may be wrong, but is'n't it something to do with the pressure build up in the cylinders, for the reason of taking off the connecting rods.
Blink Bonny
Post by Blink Bonny »
If the drain cocks stick closed and water gets in there - carnage. Plus not compressing air to be expelled through the chimney makes life easier for the engine doing the dragging.
Saint Johnstoun
Sorry to disappoint you folks but the likely reason for removing the rods was to make manhandling easier. I am sure they would be replaced once the locomotive had been placed in its static display location. It looks as if the site was restricted so mechanical propelling was out.
Post by 60800 »
Neither Mallard or Green Arrow have had theirs replaced from the trip to Barrow Hill
Neither of them are in working condition. Who knows whats missing underneath.
