Modellers' Parts & Materials Directory
This forum is for suggestions and discussion about this site. What would you like to see?
Moderators: 52D, Saint Johnstoun, richard, Tom F, Rlangham, Atlantic 3279, Blink Bonny
2002EarlMarischal
Post by 2002EarlMarischal »
I would like to suggest a directory for modellers where a typical post might be entitled "4mm A3 superheater header covers" or "N-gauge handrail knobs". Members could post details of suppliers used etc. I am sure this would save time and repetition in the modelling forum itself.
richard
Re: Modellers' Parts & Materials Directory
Post by richard »
See my usual reply to requests for more forums :-)
This might be an idea for a hierarchical forum - ie. a sub-forum. I'm not sure how well such a system would work though.
In the 3-6 month time frame I am going to be migrating my web sites to a different system. Same vendor, but they should be a little bit more resilient, much bigger capacity, and the same price. I will be taking the opportunity to upgrade the forum software at the same time.
2002EarlMarischal
Points all taken on board thank you Richard. In fact a very big thank you for an excellent forum which has very much become part of my daily routine! :D
Good luck with the migration in due course! :)
Post by Bill Bedford »
You mean you don't have this page in your 'favourites' ? http://www.clag.org.uk/russ/supplier.html
mojo
Post by mojo »
Looks good Bill, is there one for N gauge?
Maurice C.
richard
Post by richard »
I could add a static page like that (perhaps with the further information/bibliography), rather than as a sub-forum. The only problem is keeping it maintained.
mojo wrote:Looks good Bill, is there one for N gauge?
http://www.ngaugesociety.com/index.php?page=links
2002EarlMarischal
Bill Bedford wrote:You mean you don't have this page in your 'favourites' ? http://www.clag.org.uk/russ/supplier.html
Thanks Bill - it's in "Favourites" now!
PGBerrie
Post by PGBerrie »
The N Gauge Society's list is far from complete - N Brass, Ten Commandments etc. are missing. Then there are the bits and pieces. If I want to build the C13 from Worsley Works where do I get the wheels, motor, vacuum pipes, chimneys etc. In 4mm if you trawl through the model railway workbenches, you can find these things, but no-one seems to kit build locos in N gauge (I hope someone contradicts me here!).
Peter
Blink Bonny
Post by Blink Bonny »
The 2mm boys DO kit-build, but they use much finer wheels and split chassis. Having seen a 2mm 9F with the body off, it looked more like watch making to me than loco building!
Anyway, they're worth a try for bits and pieces. N Gaugers tend to use RTR chassis.
