What number series' were the different diagrams of brake vans allocated?
Nova
Post by Nova »
I'm in the process of planning an LNER based model railway and I need information on the numbering sequence of brake vans throughout the different diagrams
from what I can gather looking at pictures, a large number of the Toad-Es were numbered in the 178XXX series, but there also seems to be photos of Toad-Es with numbers outside that range, so I'm a little confused as to how the LNER went about numbering their frieght rolling stock.
additionally, if any of you could point me towards a book that contains information of the numbers allocated to different LNER wagon diagrams it would be very much appreciated
richard
Re: What number series' were the different diagrams of brake vans allocated?
Post by richard »
Tatlow's "LNER Wagons" is going to be the reference of choice.
He did a one volume work that is cheaply available, but really you should go for the five volume work even though it costs a lot more. My set is packed away (between houses) but it will be either vol. 4A or 4B you want - they cover LNER diagrams. (v1-3 cover constituent companies).
You will also find the photos and drawings useful, as well as the summary listings of numbers.
65447
Post by 65447 »
LNER Wagons Volume 4B covers the LNER standard brake vans - ISBN 978 0 953877 11 9. The running numbers for the Toad E are all listed on p317.
I'd copy the number ranges into this post but, if you are planning a model and clearly are seeking accuracy in your representation, you will find the book well worthwhile. It can be reserved through your local library if you want to review it before purchase. If you do buy it, then note that there are 4 preceding volumes, of which 1 covers the GC, GN, GE and ex-Metropolitan stock, 2 covers the NE, Hull & Barnsley and M&GN, 3 the Scottish lines, 4A the standard LNER opens, minerals, hoppers and standard and special vans and 4B the remainder of the standard LNER types.
Nova
Post by Nova »
65447 wrote:LNER Wagons Volume 4B covers the LNER standard brake vans - ISBN 978 0 953877 11 9. The running numbers for the Toad E are all listed on p317.
richard wrote:Tatlow's "LNER Wagons" is going to be the reference of choice.
Thanks, I'll be sure to look into them
Post by Hatfield Shed »
Nova wrote:Thanks, I'll be sure to look into them
I'll anticipate your next post: so many possibilities for model making, so little time.
