Drawings for J72 Modified Chimneys
MartinWales
GNR J52 0-6-0T
Post by MartinWales » Fri Feb 22, 2019 4:14 pm
Further to planning a model of an ex GC (WMCQ)line in the mid 1950's, I propose to model the four J72's which were modified with smaller chimneys (68671,68701,68714,68727).
Is anybody aware of any drawings of the above and where to find then?
MartinWales
GNR J52 0-6-0T
Re: Drawings for J72 Modified Chimneys
Post by MartinWales » Wed Mar 20, 2019 11:56 pm
Bump!
No one come across any works drawings for this? Some were modified at works visits others done on shed.
john coffin
NER C7 4-4-2
Post by john coffin » Thu Mar 21, 2019 1:31 am
There are some drawings in Ken Hoole's NER locomotives, but to find more detailed stuff, you need to
try and find out where the mods were undertaken, then check out the York or Darlington lists,
or maybe Stratford. Since the class was built again during late LNER/early BR times, it would be
worth looking at lists of GA's for there too.
Pebbles
Post by Pebbles » Thu Mar 21, 2019 10:27 am
There are photos in Yeadon's of all four engines -pages 53 and 56. In Hoole's book there are dimensioned drawings of various NER chimneys. From this a possible candidate would be a D17 chimney minus the capuchin, this would give a 7.5inch reduction in overall height not the 10inches quoted in RCTS. However, RTCS also states the reduction brought the chimney to the same height as the dome, which from a visual check of the photo of 68671 may not have been the case. Finally, it should be possible from the photo of 68671 to scale off the approximate size and dimensions.
Pebbles
Post by Pebbles » Thu Mar 21, 2019 11:10 am
I've just scaled off from the photo of 68671 and make the chimney approximately 2ft 6inchs in height- same as the D17 chimney minus the capuchin.
MartinWales
GNR J52 0-6-0T
Post by MartinWales » Thu Mar 21, 2019 6:55 pm
Gents
Many thanks for the replies and information
Have the Yeadon's volume but not Ken Hoole's book.
Another to look out for!
croesnewydd
GER J70 0-6-0T Tram
Post by croesnewydd » Wed Apr 10, 2019 8:46 am
The J72 chimneys were reduced by 12 inches to get under the bridge at CQ.
Incidentally I thought there were only three of them (2184, 2320 & 2307), but on re-reading my books they were joined by 1715 in 1942.
The chimney height was 11 ft 0.5" above the rail and it is claimed they retained the shape/style of the original.
These were normally employed at Birkenhead Docks but were supposed to replace the J62s on the Buckley line if needed.
Incidentally, Buckly (Old) station might make a good model if space is short.
Try the Buckley Railway (published by the Buckley Society) for lots of pictures of this line.
MartinWales
GNR J52 0-6-0T
Post by MartinWales » Sun May 12, 2019 10:39 pm
Hi John
Many thanks for the information
Have the Buckley book and looking long and hard to enable it to fit in a modest space in a small 2 bed cottage!
