Page 2 of 3
Re: North Eastern Railway Snowplough No 12
Posted: Wed Oct 15, 2014 2:13 pm
by Rlangham
DJR - I want one! Where is it from? Do they do N gauge too? Cheers!
Posted: Wed Oct 15, 2014 8:01 pm
by 52D
Want 2 in OO Gauge.
Posted: Thu Oct 16, 2014 6:56 am
by 69843
Well, that makes two people working on 3D printed snowploughs. I'm doing the 1909 built, wooden framed trio (18-20), with a lot of help from Bryan:
Posted: Thu Oct 16, 2014 10:06 am
by DJR
Good Morning,
Thanks for all the interest in my snow plough!
I've made a couple of changes to the model since I had that one printed, here is my model:
I will make it available at some point, just please bear with me, I want to make sure it is right! I originally made the model just for myself as a challenge!
Shildonlad - Are you from Shildon? you're not far from me if you are, I'm from Teesside and work in Newton Aycliffe. I based my model on No 12 at the museum in Shildon as it was easy to get to.
Rlangham - I could certainly attempt to scale it down to n gauge, however I suspect you might lose the timber detail as I have drawn the min groove permissible for 3D printing for the OO version. I think the gap may look too big in n gauge! But its worth a try.
69843 - Looking good, let me know if you need any help/advice.
My model with transfers:
Does anyone have any info on liveries and dates. I have Ken Hoole's NERA booklet on snowploughs, it says after NER livery it was light blue then dark blue under LNER, then black then olive green. I wonder if any one knows of any photos of ploughs or other works vehicles in these liveries?
All the Best,
Posted: Thu Oct 16, 2014 1:02 pm
by 69843
Looks excellent mate. The only question I have for the time being is how have you done the wheelbase? As I know 6w vehicles are hard to get around curves.
As to liveries, Bryan certainly can help if you PM him (if he doesn't find this before). In a 120pg document he sent me on the history of all the snowploughs, there was an excellent section on liveries. Certainly a great help for when I get around to having mine finished off.
Posted: Thu Oct 16, 2014 1:47 pm
by DJR
I got a piece of metal tube 4mm O/D x 2mm I/D and cut slices off to make bushes for the wheels. I drew a space for the bushes to snap in, as you can see in the picture. It is a 4mm hole with a 3.75mm gap in the top, worked a treat! The centre wheelset has a recess either side to allow it more side to side movement for corners.
I'll take a picture of the underside of the prototype for you tonight when I get home
Posted: Fri Oct 17, 2014 12:12 am
by 69843
That's quite clever. I'd certainly be interested to see the arrangement in practice.
Under mine I'm going for a pivoting system of, essentially, W-irons to allow it to traverse down to Radius 2/438mm curves where needed. I'll try and get a screenshot later.
Edit: The underframe in place, both on a straight and on a curve of 438mm radius, and the chassis parts.
The central section doesn't pivot, just the outside two arms and there are weight pockets in both arms to help when being pushed around. They are designed to take Markits top hat bearings and 12mm, 8 spoke split-spoke wheels on a 26mm pinpoint axle.
Posted: Fri Oct 17, 2014 12:45 pm
by DJR
Moderators - Are we ok discussing these models here? or would you rather I started a new thread in the model Railways section, I realise this probably isn't the right place!
69843 - Interesting arrangement. Do you know which material you are going to use? I used polymide, the cheap option for mine. Its quite hard and not very flexible, are you planning on snapping the wheelsets into place? Might prove a bit difficult if you are.
My snow plough goes round 2nd radius fine, I haven't tested to see just how tight it can manage.
Posted: Fri Oct 17, 2014 2:19 pm
by richard
Yes you should probably move to Model Railways.
This is all 4mm?
Posted: Fri Oct 17, 2014 7:33 pm
by Bryan
Detail as requested.
This is what I received following an enquiry to the NRM in York prior to the restoration work on No 18
Livery Detail from NRM file on Plough No 12.
PAINTING SPECIFICATION
LIVERY
NER BODY INDIAN RED
REAR BULKHEAD SIGNAL RED
ROOF WHITE LEADED
INTERIOR UPPER ½ FROM WAIST STONE
LOWER ½ INDIAN RED
CEILING WHITE
FLOOR DARK OAK STAIN
LNER LIGHT BLUE, then later DARK BLUE.
BR BLACK then OLIVE GREEN then later DEPARTMENTAL GREY.
LETTERING WHITE BLOCK with BLACK DROP SHADE to right and below
1 plank high.
Paint preparation All burnt off and sanded.
Priming 2 coats of Aluminium oxide wood primer to all wood surfaces.
1 coat of anti corrosive paint to all metal surfaces.
Priming 2 coats of Red Oxide primer to all surfaces.
Basecoat 2 coats of Indian Red to form a base for final colour.
Finish Lightly flat and apply 2 coats of indian red to finish.
Rear Bulkhead Signal red.
Roof 5 coats of white basecoat to give appearance of being leaded.
Interior Lower ½ to waist Indian Red
Upper ½ from waist Stone
Ceiling White
Floor Dark oak stain.
Posted: Fri Oct 17, 2014 11:54 pm
by 69843
richard wrote:Yes you should probably move to Model Railways.
This is all 4mm?
Shall do. It is all 4mm
Posted: Sat Oct 18, 2014 9:14 am
by twa_dogs
Very nice indeed.
I need to check the numbers , but I could be interested in a pair. I've got the Darlington pair for the late 1950's and the Kirkby Stephen steel pair to do. For those I was thinking a set of flat sections to act as a scratch build aid on a modded wagon frame using Dave Bradwell springing plates/Bill Bedford spung W-irons (P4 model, I'm afraid). How feasible would a pair be with a hollow underside to allow own suspension setups to be added?
Posted: Sat Oct 18, 2014 10:46 am
by 69843
twa_dogs wrote:Very nice indeed.
I'll start up a thread in the next 24 hours for the modelling side but from Bryan's notes provided to me, from 1958 until 1972 18 and 20 were at Darlington.
Posted: Sat Oct 18, 2014 6:47 pm
by Bryan
18 and 20 were the last Timber ploughs after 1958 and spent time at Darlington.
15 and 16 I have recorded as being at Darlington until 1958. Alongside 18 and 20
Posted: Mon Oct 20, 2014 11:33 am
by DJR
Hi Bryon, thanks for all the very useful info!
I've started a new thread in 'Model Railways'
viewtopic.php?f=3&t=10427
