help again
help again
This lone pic is one of a bunch i bought recently purporting to be of NER origin, i have recognised and catalogued the rest but the identity of this one eludes me. Possibly GNR or GCR even GWR went through my mind as usual all help welcome, the number looks like 30A.
Re: help again
I have feeling that this is from a Real Photos negative in which case it should be possible to identify it without question. I will have alook through my old lists for the 'R' reference.
Re: help again
Thank you Mr Fox.
Re: help again
2512silverfox wrote: ↑Sun Jun 04, 2017 10:26 am I have feeling that this is from a Real Photos negative in which case it should be possible to identify it without question. I will have alook through my old lists for the 'R' reference.
Before silverfox finds out I am fairly certain the loco isn't a GNR or GWR loco (I could be wrong?) although I did think originally it may have been a LNWR loco then a GER loco then a MSL (Manchester Sheffield & Lincoln) loco but now I believe it maybe a Caledonian Railway loco?. (that's 4 railway companies down only another 150 to go!).
To be honest I don't really know much about 'early railways' from the 1840s & 1850s so I'm probably wrong with my assumption?.
Re: help again
I think it is more likely to be either a Massey Bromley off the GER, or as others might have said, Caley.
The splashers are certainly reminiscent of both, whilst the cab is more GER methinks.
Re: help again
It is certainly not of NER origin. However there is the look of LNWR about the photo, but cannot be more precise.
- billbedford
- H&BR Q10 0-8-0
Re: help again
Yep, it's a Crewe type, but lots of companies built Crewe types.
Re: help again
Caledonian Conner 88 Class No.90A
The New Aberdour Branch in 7mm - https://www.flickr.com/photos/57586155@ ... 2782514711
Re: help again
Yeah the cab and splasher has a vague Caledonian Railway look about them and the front end smokebox and outside cylinder housing has a bit of a LNWR look about them.
So it's a 'Cally loco' after all John
Re: help again
Thanks for helping me get to the bottom of this one, till the next one, cheers fellers.
