The NBR S Class (LNER Class J37) is a class of 0-6-0 steam locomotive designed by William Paton Reid for freight work on the North British Railway. The engines were initially designated as B class, being a development of the standard B class locomotives designed by Reid some eight years previously, and represented the culmination of a long evolution on the NBR of powerful 0-6-0 freight engines. The new locomotives were introduced in 1914 and had superheaters, inside cylinders and piston valves operated by Stephenson valve gear
The North British had built large numbers of 0-6-0 freight engines of earlier classes, and during the incumbency of Matthew Holmes these reached his highly numerous C class design, consisting of 200 locomotives in total (168 of his own engines, later designated LNER class J36, plus 32 rebuilt from the highly similar 1876 design by Dugald Drummond, later designated LNER class J32).
Reid set out to develop this design, and improve upon it, producing the standard NBR B class (later LNER class J35), of which 76 examples were built. They were larger and heavier than the earlier engines, and in common with Reid's common practice, had a high boiler pitch.
In 1914 Reid ordered the first batch of 5 engines of his improved B class design. From 1914 to 1919 these engines were simply considered to be part of the B class, by which time around 70 had been produced. However, with a new batch ordered in 1919 Reid made several minor alterations, including an increase in working boiler pressure from 165psi to 175 psi. These engines, together with all subsequent batches, were given a new designation, as S class. Several of the earlier locomotives were upgraded to the new 175psi boiler pressure, and redesignated as S class. Finally, upon grouping in 1923, the LNER upgraded all of the S class engines and all of the improved B class engines, to a working boiler pressure of 180psi, and formally grouped them all together into the J37 class. The improved B class J37s and the S class J37s together totalled 104 engines.
A total of 104 locomotives was built by the North British Railway, all of which passed to the London & North Eastern Railway (LNER) at grouping, and all of which came into British Railways (BR) ownership at nationalisation in 1948. BR numbers were 64536-64639
Like the earlier standard B class (J35), none of which survived after withdrawal, the improved B class (J37) and S class (J37) engines were all scrapped. No example survived for preservation.
9306 mineral train near Eastfield June 1929
https://railway-photography.smugmug.com ... /i-WGk9BsJ
Reid J37 (NBR Classes B & S) 0-6-0 Locomotives - Railway-Photography
9073 Killingworth June 1931
https://railway-photography.smugmug.com ... /i-hN39tCq
9273
https://railway-photography.smugmug.com ... /i-9z3zcCs
9431 Crossing Forth Rail Bridge
https://railway-photography.smugmug.com ... -fBnKMxL/A
9457 near Eastfield June 1929
https://railway-photography.smugmug.com ... -Nsrtgtg/A
9464 Eastfield 1929 Reid J37
https://railway-photography.smugmug.com ... /i-hHV223X
4572 Craigentinny
https://railway-photography.smugmug.com ... /i-BwRsVDc
4574 Craigentinny
https://railway-photography.smugmug.com ... /i-DKDMkF6
4589 Polmont 22nd May 1948
https://railway-photography.smugmug.com ... /i-Fmxd7NX
4597 Eastfield shed 16th June 1949
https://railway-photography.smugmug.com ... /i-hpXSqJ4
Neil
N.B.R./LNER J37 0-6-0
Re: N.B.R./LNER J37 0-6-0
Newly added over 50 photos in B.R. days
64543 Dunfermline shed 15th August 1960
https://railway-photography.smugmug.com ... /i-5sDKkjL
64547 with white highlighting Dundee Taybridge station c1965 Reid J37 (NBR Classes B & S) 0-6-0
https://railway-photography.smugmug.com ... /i-8g948xS
https://railway-photography.smugmug.com ... /i-FzgL3S4
64570 Thornton 11th June 1966
https://railway-photography.smugmug.com ... /i-n5RDMcg
64574 Dundee Tay Bridge shed 14th April 1956
https://railway-photography.smugmug.com ... /i-NHrbJ8t
64587 Rosslyn Lee Hospital halt 3rd February 1962
https://railway-photography.smugmug.com ... /i-KsHRN43
64588 Largs June 1965
https://railway-photography.smugmug.com ... -fVMQWQ3/A
64599 Leith Docks 25th August 1962
https://railway-photography.smugmug.com ... /i-6qWzrRB
64606 Thornton Jct 22nd September 1966
https://railway-photography.smugmug.com ... /i-BjTGdJP
64608 Portobello West 16th January 1955
https://railway-photography.smugmug.com ... /i-fz97Dph
64611 Polmont May 1963
https://railway-photography.smugmug.com ... -nsGFx55/A
64615 Montrose 16th June 1960
https://railway-photography.smugmug.com ... /i-TNHLqXD
64617 Alloa Shed 3rd October 1959
https://railway-photography.smugmug.com ... /i-npMxSF7
64622 Edinburgh Waverley
https://railway-photography.smugmug.com ... /i-9scjWsb
64624 Craigentiny 24th June 1961
https://railway-photography.smugmug.com ... /i-8Dd2bjh
64627
https://railway-photography.smugmug.com ... /i-Q55Q7zd
64636 Inverkeithing 20th June 1959
https://railway-photography.smugmug.com ... /i-ZrmSmcj
Neil
64627
Neil
