Worsdell NER & GE Locos
Moderators: 52D, Rlangham, Atlantic 3279, Blink Bonny, Saint Johnstoun, Tom F
- LNER P2 2-8-2
Hi All
I have added a new collection of NER/GER Worsdell loco designs, some from there BR days and others from Preservation
65033 J21 (NER Class C) Darlington
http://www.steamlocomotives.photos.gb.n ... 80707.html
65717 J25 Deepdale Viaduct 29/8/1952
http://www.steamlocomotives.photos.gb.n ... 80695.html
65849 J27 (NER Class P3) Whitby fitted with snow plough
http://www.steamlocomotives.photos.gb.n ... 80699.html
68716 J72 (NER Class E1) 0-6-0 Tank Engines C1961 unknown location
http://www.steamlocomotives.photos.gb.n ... 80698.html
1621 North Eastern Worsdell Class D17/1 (NER Class M1 & Q) 4-4-0 Locomotives York
http://www.steamlocomotives.photos.gb.n ... 80711.html
65033 J21 (NER Class C) Doncaster works
http://www.steamlocomotives.photos.gb.n ... 80701.html
http://www.steamlocomotives.photos.gb.n ... 80705.html
65033 Crewe Works? or Doncaster Works?
http://www.steamlocomotives.photos.gb.n ... 80702.html
http://www.steamlocomotives.photos.gb.n ... 80700.html
2392 J27 (NER Class P3) NYMR
http://www.steamlocomotives.photos.gb.n ... 80708.html
http://www.steamlocomotives.photos.gb.n ... 80704.html
http://www.steamlocomotives.photos.gb.n ... 80710.html
2392/75078 Haworth
http://www.steamlocomotives.photos.gb.n ... 80709.html
(Now with BR number)
65894 J27 (NER Class P3) Haworth KWVR
http://www.steamlocomotives.photos.gb.n ... 80697.html
http://www.steamlocomotives.photos.gb.n ... 80703.html
http://www.steamlocomotives.photos.gb.n ... 80706.html
65894 unknown location
http://www.steamlocomotives.photos.gb.n ... 80696.html
Neil
2392/75078 Haworth
Neil
Re: Worsdell NER & GE Locos
Mr Dimmer i must take you to task, Mr Harrison et al will be spinning in their graves after you attribute a certain aforementioned class of 4-4-0 to the Great Eastern.
- LNER P2 2-8-2
52D wrote:Mr Dimmer i must take you to task, Mr Harrison et al will be spinning in their graves after you attribute a certain aforementioned class of 4-4-0 to the Great Eastern.
Ooops do not know why i put Great Eastern instead of North Eastern
Neil
The other two 65033 works photos are also at Doncaster, Neil.
The 65033 pics at Donny(Darlo?) were probably taken around the time the two survivors were on the scrapline together, parts were being swapped to make up the best one for preservation. Shame we couldnt have kept both in the words of Rev Awdry we would have TWO VERY USEFUL ENGINES.
I have been looking at the picture of the J72. It appears to be bearing a 50B (Hull Dairycoates) shed plate and it moved to Dairycoates from Darlington in 1960 previously being shedded at West Hartlepool. It was withdrawn in March 1961 & cut up at Darlington. However, the coaling plant is not Dairycoates nor is it Botanic Gardens but it does look like York, I can't find a picture of Darlington coaling plant which is obviously a possibility.
Any further comments?
I wondered if the J72 had strayed across the Humber to Immingham then thought better of it. Surely the coaling tower is a give away, its too far south for me to comment.
Very nice photographs, thanks for sharing
I'm pretty sure it's York. Certainly not Darlington, which had a very distinctive coaler.Solario wrote:I have been looking at the picture of the J72. It appears to be bearing a 50B (Hull Dairycoates) shed plate and it moved to Dairycoates from Darlington in 1960 previously being shedded at West Hartlepool. It was withdrawn in March 1961 & cut up at Darlington. However, the coaling plant is not Dairycoates nor is it Botanic Gardens but it does look like York, I can't find a picture of Darlington coaling plant which is obviously a possibility.
Kudu
