Scotsman MAJOR Update - week4
Major work done in the last week, from last weeks, 'half' casing off, to this.
Have a look at this little lot!!
I thought she had an A4 Boiler on, with a little 'slope' on the front, but it doesn't!
Other bit's of note, She has moved to the far track from the middle (Green Arrow coming out??) and Green Arrows tender that was on the left of the far track, has now swapped places with Scotsman's, although I couldn't get a close up picture of Green Arrow's tender as the warehouse is closed for the building from I think the 9th -23rd, and the path is shut off before the tracks.
Mark t
Mark t
I DID NOT KNOW that the bit at the front was sperate is what I'm saying, and the slope isn't actually on the boiler.
SORRY
Mark t
SORRY
Mark t
What are you talking about, the last post I made was just a reply to "sir-nigel", why are you getting so worked up about something that wasn't even directed remotely at you?
You also did a similar thing in my previous post where I just explained about the A3 and A4 boiler differences, for you to just say:
Is that not slightly childish???, after all aren't these forum's here to discuss and find out information!?!x568wcn wrote:I didn't say it did require a sloping smoke box
Yes but since I wrote that I have learn't (Which we are all put on the earth for) that there is an extra bit on the front which isn't a prt of the boiler.
When you don't know something Yes, I think it is being Childish, as this is the time you learn the most in your life, so the fact I didn't know something must mean I didn't yet learn it at School.
Reet I'll never post again, and I'll cancel myself from this Forum, so no more postings on Scotsman (I can hear you all cheer)
Thanks for the little time I've been on, this is Mark Signing out
I asked the question, you put a picture on saying it doesn't require a sloping Smoke box, I said I didn't say I did, as I thought it was part of the boiler, and the A4's have a slope on the front.
Sir Nigel posts pictures of Sir Nigel with and without the smoke box, where I can then see it is a sperate peice, which you blew out of proportion.
I thought the post was then posted at me aswell as Sir Nigel, and YOU then had a go at me for being CHILDISH???
I've always like steem trains, but just latley been intrested to find out about them. I have seen pictures of steam trains in bits, and in full, but never have I seen a stream train coming apart bit by bit, which I think not too many people have.
I heard that Scotsman had an A4 boiler on, which needed a slope on the front for the streamlined casing. I didn't know the front bit was seperate and interchangable.
So the fact Scotsman has an A4 boiler doesn't matter as the A4 and A3 are the same then??
Yours
M
Yours
M
- richard
<moderatorial cough>
I'd have to look up the details, but the A3s, A4s, and V2s had very similar, but different boilers.
Many of the A3s were fitted with A4 boilers later in their lives, and Thompson considered fitting V2 boilers to A3s (but this never happened).
The A4 boiler represented an incremental improvement over the A3 boiler mainly due to its higher working pressure. The A3 was in turn an improvement over the A1 boiler with its higher working pressure and significantly larger superheater.
Richard[/i]
Richard[/i]
- LNER J94 0-6-0ST Austerity
