That bad already?
G-Train Locomotive Works / Graeme King Joint Venture - GCR/LNER 4-6-0s - B3/1 & B7 available; B3/2 in progress
Re: G-Train Locomotive Works / Graeme King Joint Venture - GCR/LNER 4-6-0s - B3/1 & B7 available; B3/2 in progress
Quick update.
Revised B3/2 etch design now in hand and to be submitted to etchers with estimated 4-6 week turn round for a further test build of the revised parts.
Meanwhile, the camboxes will be a 3D print. Have seen a first test print which had a dimensional error but otherwise looks OK.
(recreating pre-war Grantham in model form http://www.lner.info/forums/viewtopic.php?f=3&t=9076.
Forthcoming exhibition appearances: Newcastle (Nov 2023); York (Easter 2024); Bristol (May 2024)
Error on 3D Cambox print corrected, here are some pictures today of the trial fit on the test build loco.
We're getting there ...
Is that a ICBM hiding inside the boiler, Clever.
PS, Nice loco.
PS, Nice loco.
Looks encouraging from here.
How does one aqquire a B3/1 and a B7 Kit?
You can PM Graham Nicholas (LNER4479) on this forum, or message me and I'll pass it on, or just post what you want here and I'll make sure it gets to him.
How is the project coming along? Just discovered this and I am quite interested in it.
The enquiry has been brought to his attention.
Now then - don't all fall off your chairs at once but:
Boiler test etch completed! Call it a(nother) New Year's resolution. Just sent off feedback to the designer (Nick Easton) but basically it's OK so, with two very minor tweaks, I've asked for an initial run of 10 such boilers, which should satisfy current, known orders. Plenty of Graeme's resin boilers in stock so should now be able to offer a choice of either going forward.
Now dropped on to the B3/2 test etch ...
- Chas Levin
- NBR D34 4-4-0 'Glen'
Excellent news. Well done Graham.
Morgan
Morgan
Two, please, if you can! - one for the B3/2, and the other to replace the resin one on the earlier B3.LNER4479 wrote: ↑Mon Feb 27, 2023 8:29 pm....Boiler test etch completed! Call it a(nother) New Year's resolution. Just sent off feedback to the designer (Nick Easton) but basically it's OK so, with two very minor tweaks, I've asked for an initial run of 10 such boilers, which should satisfy current, known orders. ...
Cheers!
