Micks 4mm LNER Models
Re: Micks 4mm LNER Models
Sascha,
No problem , you are welcome to use the images.
I cant remember the exact number, but you need to post a number of messages on this Forum, before you can send Private Messages.
Mick
Slanjonok
Post by Slanjonok »
Hi Mick,
Thanks a lot.
Sascha
Dave Alexander G5
3d printed Containers now loaded onto J.Wealleans/Graeme King (thanks), Container Flat Wagons resin castings .
D&S NER Bogie van
Repainted from BR livery ,current Hornby LNER Toad E Brakevan
Slaters ex NER Brake van
Parkside Conflat S with Hornby Container.
Wagons galore. Correct though they are, I've just been struck by the very short-looking wheelbase of the Conflat V wagons.
19' body and a 9' wheelbase. You wonder how they thought that would be comfortable for the cattle.
It would'nt have been to pleasant inside a Container either !! :D
Bogie Bolsters & Trolley/Plate Wagons old builds with TMC Steel plates added on
D&S ex NER
Bachmann/TMC version.
Parkside
D&S exNER
Probably my last conversion based on the Hornby A3 , this time based on a battered NRM version body.
Boiler repainted and new lining ,Footplate and Splashers new lining, Banjo Dome , Single Chimney, Handrails to Smokebox after filling a large hole !, Vacumn Pipe and Ashpan Lever , Crew. Tender I had already repainted from a Hornby BR version.
Isinglass Models 3d print of a ex GNR Restaurant car .
First time i have built one of these coaches . This has taken over a month to build , running on D&S Bogies , MJT underframe other than the Isinglass provided Gas Tanks. Lanarkshire Models Roof vents.
Advertised as a easy build ? A lot of things to watch out for parts are very fragile, hence replacement parts used as listed above. I dropped mine onto the thick carpet and one end corner shattered !! One good thing is its built using superglue, so a easyish repair.
Very hard to see any printing defects on the sides at this time. I recomend priming the outside of the sides before building. I did'nt and found numerous lumps and bumps and lines on the sides after priming, that were then a real pain to get rid off as everything is very bendy/fragile at that point as unsupported until the Roof is glued on.
I am undecided if anymore will be built. Not helped by zero instructions with the kit, just a A4 print of the Isinglass Drawing is provided. The owner is very helpful providing a new roof, as the first one was slightly too short .
Possibly the best Isinglass exterior surface finish I've seen, if those photos reveal all.
Secret store of old D&S bogies Mick?
It took over a month sorting this out , numerous lumps , bumps and "stringing" on the sides . There wasnt hardly any actual raised lines to remove. All very fragile as well. I prefer etched kits !!
The D&S Bogies were a e bay find , which I did'nt expect to win and did !! . I then had to find something to use them on !!
