Robs workbench
Re: Robs workbench...in works grey...
Should the "Fish" plate be lower as on the "Fruit" van?. Ambis do a nice etch of the Fish and Fruit plates, if you do not know.
rob
Post by rob »
hi Mick...
the two Fish are LMS and I'm going pretty blind with them,basically just following the Parkside instructions..apparently built in 1941 with absolute economy lettering,not even LMS.....I need to get a "Tatlow" for the other 3 companies really ....is there an LMS encyclopedia?...I'd happily joint one for the other 3 as I'm overloaded on LNER rolling stock....probably a common affliction!!
Rob,
Bob Essery and I think David Jenkinson produced a 2 volume set I think of LMS Stock.
Old but worth looking for.
rob
Post by rob »
...I'll keep a look out the,thank you...seems a bit daft to be producing reasonably accurate LNER stock and part-guessing the others!
rob
Robs workbench...
Post by rob »
...A very slight update......
Finished this POWsides kit...always thought that models of the Colemans advertising wagons were overcooked but found a photo in one of my PO books where the red contrasted clearly with the rest of the colours and its a thorough job....even the axles and bolt heads all in red!...I presume Colmans would have very few fully decked out like that....I did not attempt the bolt heads!
...and four Dia 3D kits... nearly ready for lettering.....
A very colourful wagon!
rob
Post by rob »
....possibly too much!...as hot as the product it advertises!
rob
Re: Robs workbench
Post by rob »
just a quick shot of the bog standard DJH D20 kit after running trials with no detail yet....still in two minds about attempting to remediate the tender frame cutouts while its in bare metal but I'm already researching the next build so maybe not!!!
I did make an effort to file the frames down as I'm considering finishing it as 1234 (which is a great number I think) in lined black....
Re: Robs workbench
You clearly haven't lost the knack of loco kit building.
rob
Re: Robs workbench
Post by rob »
.....thank you,a few slip ups but getting along!....boiler fittings done,rails and pipes next....
Re: Robs workbench
Chimney normally on cab roof?
rob
Re: Robs workbench
Post by rob »
Oh,my mistake,thanks Graeme,I'll get that sorted......thats whats great about this forum,so much expert advice! :D
