Great British Locomotives Magazine
- 2002EarlMarischal
Re: Great British Locomotives Magazine
BTW good luck to anyone trying to undo the plinth screws on their GBL A2s. I could only unscrew 1 of the 6 in my 2 models - will have to drill them out I think!
Old trick, slightly tighten to break out, then undo immediately. That got mine of its' plinth 'JLT'. The screws holding the body together were similarly well tightened.
Has anyone who has got one taken one apart yet and can confirm how it's all put together? I am thinking now that I know it's a single chimney example, of ordering a job lot as I could use them to make the rest of my A2/2s and thus save a Peppercorn A2 bodyshells to sell instead. The tenders I am unsure about but for A2/1 certainly they could be used. It's a shame they haven't seen fit to do the A1 - as well - as an apple green Darlington variant instead would be something Bachmann have never done (Tornado doesn't count because of the tender modifications).
I only really want the boiler and firebox. The 5000 gallon tender is a rivetted example.S.A.C. Martin wrote:Has anyone who has got one taken one apart yet and can confirm how it's all put together? I am thinking now that I know it's a single chimney example, of ordering a job lot as I could use them to make the rest of my A2/2s and thus save a Peppercorn A2 bodyshells to sell instead. The tenders I am unsure about but for A2/1 certainly they could be used.....
Here's how it all breaks down:
Further to above photo, the deflectors and cab are cemented in place, come free with a little knife work in the locating lugs; removing the cab also releases the cab interior parts, which were out of position on the two examples I have. The boiler skirt is ten minutes work with a fine miniature file to eliminate / reprofile, the mould part lines on the boiler sides and the awkward transition from round to flat on the RHS firebox side are easily dealt with. It could hardly be better designed as project feedstock.
The lubricators and sandbox fillers also need to be removed if you want to use the boiler and firebox to replace a kit item (I'm thinking Crownline / PDK here).Hatfield Shed wrote:.... The boiler skirt is ten minutes work with a fine miniature file to eliminate / reprofile, the mould part lines on the boiler sides and the awkward transition from round to flat on the RHS firebox side are easily dealt with. It could hardly be better designed as project feedstock.
Ivan, would you be prepared to sell or swap your tender? It'd be perfect for an A2/1 I am going to be working on shortly.
I've been unable to get any of these in the usual locations in London - so it looks like I may have to speak to the publisher directly.
No problem - name a figure, and don't forget postage.S.A.C. Martin wrote:Ivan, would you be prepared to sell or swap your tender? It'd be perfect for an A2/1 I am going to be working on shortly.....
I was lucky to find even this one; it was the last one at the local Asda. I suspect that the next one out - the Class 47 / Brush Type 4 - will be in even greater demand.
Thanks Ivan - I will send you a PM later on accordingly.
Thought: before you use it, maybe you might let Graeme assess its suitability as a master for a new tender body mould.....S.A.C. Martin wrote:Thanks Ivan - I will send you a PM....
Interesting thought - potentially could be the master for two body types (Doncaster and Darlington variants).Horsetan wrote:Thought: before you use it, maybe you might let Graeme assess its suitability as a master for a new tender body mould.....S.A.C. Martin wrote:Thanks Ivan - I will send you a PM....
Exactly....S.A.C. Martin wrote:....potentially could be the master for two body types (Doncaster and Darlington variants).
Just out of interest Ivan, how does the cab fit to the running plate? It could be an almost straight swap for a Bachmann A2 cab - if it is, it's not badly lined out - could be a way of renumbering an A2 easily to Blue Peter.
It's a clip-fit - i.e. two rectangular "prongs" under each cabside, glued into matching slots in the footplate.S.A.C. Martin wrote:Just out of interest Ivan, how does the cab fit to the running plate?....
Thanks Ivan - exactly the same as an actual A2 more or less if you remove the lugs. I reckon that would do nicely on a model I've been working on.
