Page 4 of 4
Re: Class J52 Scale Drawing
Posted: Sat Dec 12, 2015 10:05 pm
by dlester
john coffin wrote:Having checked the Doncaster list, I cannot find W226 Dlester, where did you find it please?
Be interested in anything else you have to suggest too
Paul,
It's listed on the NRM site
here.
The particular line in the record you're looking for is:
W 226N W: "Regulators and general purpose brasswork" "Cab window 0-6-0 type saddle tank engines for engines converted from J53 - J52" 19/05/1924 J53, J13
The other thing to note is that the GA for the 921 series (P-35) also includes a "detailed drawing" list on the bottom left. I'd say about 50% of these detailed drawings are actually held by the NRM, and the remainder are now missing.
Posted: Sat Dec 12, 2015 11:46 pm
by john coffin
thanks Dave, somehow it was not on a list I had.
I have P35, but technically it is not a GA, it is a pipe drawing, although really there is little to differentiate them for our purposes. Whilst pipe and rod drawings are notoriously inaccurate in terms of the layout of the pipes and rods.
Will look at it again, along with my copy of the Ivatt J52 and see what else I might need.
I am quite happy to consider a J53 in both original 921 and subsequent J52 version as a basis for both drawings and kits.
paul
Posted: Sun Dec 13, 2015 12:34 am
by john coffin
Some might disagree with my characterising p drawings as pipe and rod, but if you study the list, it is in the usual Doncaster way confusing.
For instance within the R list which is supposed to be tenders, are a number of later drawings for tanks on locos too.
Posted: Sun Dec 13, 2015 10:44 am
by Pebbles
Paul the saddle tanks and the 0-6-0 series both need addressing. John had started the J3/4 and had planned additions. I should point out that John never draw to any other size than 4mm all larger sizes were merely enlargements. The John Gardner series that were originally drawn to 3/4" and are available from the GER in both paper and on CD are much sharper in definition.
Posted: Fri Sep 13, 2019 7:12 am
by rockinjohn
Hi its going back a long way before Hornsey/Kings Cross J52's were replaced by J50's but I suppose '53/'54 stovepipe chimney &another "hump" behind the chimney 6866X or 687XX #series all roarin' up the Holloway ramp/incline from Clarence Yard "X" bound light engine...
