Potential RTR chassis to use as a base for a scratch built/kitbashed Raven EE1 spotted
http://www.hornbyinternational.com/en/r ... r2462.html
there are a few inaccuracies such as the sandbox arraignments, however I feel it's a better start than nothing at all
- H&BR Q10 0-8-0
Re: Potential RTR chassis to use as a base for a scratch built/kitbashed Raven EE1 spotted
Judith Edge do a 4mm kit .
yes but you also have to build the wheels because of their distinctive spokes, which I don't fancy attempting when I've never built a loco kit in my life. this model also seems to have the same type of wheels.mick b wrote:Judith Edge do a 4mm kit .
and from what I've heard from people in my local club Judith Edge kits are not recommended for the beginner.
I'm not experienced with brass construction but I do have experience with building using styrene sheet (admittedly for something not railway related) I'd rather get one of these and build a body to match from styrene sheet, the running board seems to be separate from the body shell so it shouldn't be to hard to use that running board as a guide for size
Yes but this is HO scale , would the wheels be the correct size for OO ?
I agree re the Edge kit wouldn't be for a beginner. But if you want correct 4mm OO scale that would be the only way to get a correct model, unless the rtr chassis has the correct size.
I'm of the opinion that as long as it looks right it is right, i don't slave over making sure that every rivet is where it should or that the wheels are exactly the right diameter.mick b wrote:Yes but this is HO scale , would the wheels be the correct size for OO ?
and from my experience you generally can't notice any inaccuracies between OO and HO unless you have two of the same subject in each scale sat next to each other, "fish-out-of-water" effect and all that.
I take much more enjoyment out of taking a pre-existing chassis, that whilst it may have slight inaccuracies, works well and adapting it for a locomotive that isn't readily produced, rather than slave for weeks over a brass kit that might not necessarily work at the end of the process and thus put me off loco kit building.
besides if someone complains that the wheels are two small then I'll simply tell them that it's representing the EE1 close to a tire change.
- H&BR Q10 0-8-0
I have to say that Nova's attitude here has a lot of merit, given his admitted skills, preferences and attitude. I for one would be interested to see how he gets on, and you never know, perhaps it will spur him on to try other things, even perhaps a JE kit, in the future
Let's face it, many of us started off doing similar things - modifying RTR stock in order to try and make it at least look something like what you wanted; indeed some folk still do
Indeed Nova has a point that I feel many miss with regards to modelling, if it looks right, then it is right. That of scale, I remember when Graham Farrish in the late 80's introduced an N guage Deltic. There were these two characters in Northumbria Models [remember that shop?], with one of these scale rulers. Where upon the systematicaly demolished the model as it was [in N gauge] 6 inches to short length ways, 2 inches to wide and 3 inches to tall, so QED wasn't a Deltic and Farrish were conning people! Thing is without the scale ruler it was impossible to say the measurements were wrong......
- H&BR Q10 0-8-0
Northumbria Models? There's a name from the past! I remember it well
sounds like they never even contemplated the process behind mass producing a model. and if they go around with a scale ruler measuring models for accuracy then I probably wouldn't even give them the time of day2392 wrote:Indeed Nova has a point that I feel many miss with regards to modelling, if it looks right, then it is right. That of scale, I remember when Grahm Farrish in the late 80's introduced an N guage Deltic. There were these two characters in Northumbria Models [remember that shop?], with one of these scale rulers. Where upon the systematicaly demolisted the model as it was [in N gauge] 6 inches to short length ways, 2 inches to wide and 3 inches to tall, so QED wasn't a Deltic and Farrish were conning people! Thing is without the scale ruler it was impossible to say the measurements were wrong......
- H&BR Q10 0-8-0
Sadly there are still a few folk who are, well, obsessed with even the most minor of detailsNova wrote:
But don't let that sort of attitude put you off this challenge that you've found for yourself
Of course, the MOST important thing to sort out, right from the outset, is the livery...
This was one classic path into making your own models when very little could be got RTR. It teaches you things too. Take a RTR J72 and it's got most of the parts on it which - supplemented with some sheet material to produce the different cab and tank side profiles - are required to cobble together a recognisable GER J67/69. Now why would that be then?markindurham wrote:...Let's face it, many of us started off doing similar things - modifying RTR stock in order to try and make it at least look something like what you wanted; indeed some folk still do.
Maybe build the NER electric as the 'production version' one of the improvements on which was smaller driving wheels...
I think there was an outline for a smaller-wheeled version, which I will try to look up later.
I like the NER electric locomotives. I had hoped to find space on my new railway for a small section of OH and one of the Shildon electrics, but unless I have a brainwave in the next few days I don't think I'm going to manage it. Never mind! A future project perhaps.
As regards 'model bashing' something to reflect a different prototype than the one originally intended, then what can sometimes seem an attractive path can ending up being problematical. On the other hand, it can be a good learning tool.
Unless the changes required are relatively easy to achieve then I suspect, from my recent experience, it might be easier to scratch build.
Having said all that, I am contemplating something quite heretical at the moment........
LNER post-war, of course, and the type of layout I'm doing will justify using it as a regular ECML performermarkindurham wrote:Nova wrote:
See here for a full explanation of what I'm talking about: viewtopic.php?f=3&t=11905
I'll be leaving the chassis virtually untouched besides paint, and I'll be making the bodyshell, which is rather simple as far as locomotive designs go, from scratch.drmditch wrote:
