Page 1 of 1
Ex-Kitmaster (Dapol) Brake van to an LNER LWB toad?
Posted: Mon Nov 28, 2016 3:28 pm
by Nova
I currently have a Dapol OO brake van unassembled at home and I'm wondering what, if any, work is required to convert it to an LNER long wheelbase Toad
Re: Ex-Kitmaster (Dapol) Brake van to an LNER LWB toad?
Posted: Mon Nov 28, 2016 3:36 pm
by jwealleans
On my workbench, November 2010, starts
here.
Posted: Mon Nov 28, 2016 5:06 pm
by 65447
First off it's ex-Airfix and second it gets the full treatment by Geoff Kent in 'The 4mm Wagon Part 3', Wild Swan.
Remember too that there was more than one variant of the LNER Toad 'D' without and then with concrete ballast (change to overall height), without and then with the small angle trussing to underframe, various positions for lamp brackets and variations to height of vacuum pipes for starters...
Posted: Mon Nov 28, 2016 5:21 pm
by jwealleans
Picking up on '47's point, you're better off starting with an Airfix moulding as the plastic is of much better quality. They're still very readily available.
Posted: Mon Nov 28, 2016 5:35 pm
by Nova
65447 wrote:First off it's ex-Airfix
apologies, Dapol now puts Kitmaster on the packaging of most of their kits including the brake van so I assumed that it was one of the ex-Kitmaster mouldings
I was not aware of this, my knowledge of any wagon, let alone LNER ones, is basic at best.
jwealleans wrote:On my workbench, November 2010, starts
here.
thank you, though given my skill level I'll probably only shorten the foot boards and remove the concrete weights, enough so that those in the know will be able to say "that's a Toad-D, though [insert detail] isn't quite right", I've got many years ahead of me to make more attempts so I'm content to start off with the most glaring differences then add more details to subsequent versions as my skill level increases.
Posted: Mon Nov 28, 2016 5:39 pm
by Nova
jwealleans wrote:Picking up on '47's point, you're better off starting with an Airfix moulding as the plastic is of much better quality. They're still very readily available.
I already have the Dapol one though, and neither the money nor the ability to source an airfix one,
A case of "make do and mend" if ever there was one
Posted: Mon Nov 28, 2016 6:31 pm
by williewhizz
On all matters regarding adapting and modifying freight stock, the Geoff Kent books are a quite superb first port of call. It might be said they're starting to get a bit long in the tooth now, but most of the models he works on are still around; although a few of his conversions are no longer necessary as excellent kit or R-T-R versions are now available.
Posted: Mon Nov 28, 2016 6:59 pm
by D2100
williewhizz wrote:On all matters regarding adapting and modifying freight stock, the Geoff Kent books are a quite superb first port of call. It might be said they're starting to get a bit long in the tooth now, but most of the models he works on are still around; although a few of his conversions are no longer necessary as excellent kit or R-T-R versions are now available.
Around a quarter century since Vol 1 ...
#shudders... But Geoff always intended the approach to be modular and lateral, the projects don't have to be copied literally. The techniques, once learnt, apply to more or less any wagon, and research will turn up more variations than he could possibly have covered.
Posted: Mon Nov 28, 2016 7:23 pm
by 65447
Nova wrote:65447 wrote:jwealleans wrote:On my workbench, November 2010, starts
here.
You do not have to remove the concrete weights as the LNER built many with them - a way of saving scrap metal ballast enabling it's use in the war effort. If you retain the concrete then you almost certainly also need to have the small angle trussing to the underframe. The end doors would be either solid wood - no windows in them - or later just two panes not four and, yes, shortening the footboards will create the most obvious difference between the LNER and BR versions. Either type of axlebox as long as it's not roller bearing and more slender buffers rather than the eventual OLEO type fitted by BR; it's been so long that I cannot remember exactly what was in the Airfix kit.
Whilst it is not exactly correct in all respects this TMC model, by Bachmann, will give you a very good idea of how your conversion should look:
http://www.themodelcentre.com/37-529ZTMC-1/
Posted: Sun May 05, 2019 8:57 am
by earlswood nob
Good morning from sunny Surrey,
I've just found this thread. It's interesting as I picked up a Dapol Brake van a few weeks ago and started converting it.
It is currently awaiting axleboxes, which I forgot to look for at a recent exhibition visit.
