Atso's new loco works
Atso
Re: Atso's new loco works
Post by Atso » Thu Oct 26, 2017 6:28 pm
Not a huge amount of progress recently having been working on some bits and pieces of other's. However, I've hit a bit of a wall and so I've turned my attention to one of the NQP Dapol A3s I picked up at the Dapol open day a few weeks ago.
Work so far includes stripping the locomotive of its identity and transplanting various bits from one side of the locomotive to the other to represent a right hand drive A3. It also needed some attention to its valve gear and drive shaft (hence it being a NQP sale). I'm looking to ultimately make this one into Harvester in mid thirties condition.
Atso-Cad Models
www.atso-cadmodels.co.uk
Atso
Post by Atso » Fri Dec 08, 2017 10:40 am
A bit of a flurry of activity finally happened yesterday when I realised that the latest date for Shapeways orders was fast approaching!
In total five tank locomotive bodies were ordered as tank engines are difficult to print in one piece on my own machine due to the available build area I have. Included was an updated V1 which has had a few corrections made compared to the incomplete one previously shown. Others included:
The V3 version...
An A5/2, I did the CAD for this last year and thought it was long overdue for printing. It'll likely end up as 5007 as I've got a picture of that locomotive running on a train out of Kings X
A non LNER locomotive!!! Have I just committed a cardinal sin?!! :twisted: A Stanier 2P 0-4-4 body! As the LMS ran some suburban services on the ECML up to Potters Bar, I thought it would be nice to represent some of these. It would appear that such services were handled almost exclusively by Jinty locomotives (although I understand a Fowler 3P could occasionally be seen). However, I've always had a soft spot for the 10 Stanier 2Ps (a locomotive that he had nothing to do with the design of!), and so rule one will apply!
Atso-Cad Models
Atso
Post by Atso » Thu Dec 14, 2017 4:46 pm
Thanks to the ever helpful people at Dapol managing to source and supply some spare valve gear, my Flying Scotsman project is back underway.
Still plenty to do in terms of patch painting and lining but nice to have this loco running again. This locomotive came to me as a damaged, non-running, Papyrus and was really in a poor state. A spare A3 4472 cab has been substituted (I was lazy in not renumbering and had the cab to hand) along with a corridor tender that has been de-streamlined and re-lettered. Other work done includes moving various gubbings from the left hand side to the right and carefully filling off the superheater header covers. It's supposed to represent the locomotive in early 1930's condition and therefore the cab isn't correct but I can live with this (and some other minor points).
Atso-Cad Models
BlythStationLad
Post by BlythStationLad » Sun Jan 14, 2018 10:00 pm
Really interested in a V3. Any suggestions as to a chassis suitable for DCC?
Atso
Post by Atso » Mon Jan 15, 2018 10:11 am
Hi, thanks for your interest. The V1/V3s are designed to fit a modified Farish N class chassis which is DCC fitted. However, at the DCC plug is located in the tender you'll have to move it into the cab area. This isn't too difficult but does require you to either cut the front out of the tender chassis or unsolder the wires leading to the plug using the smallest soldering iron bit you can find and then resoldering it once removed.
You'll need to wire the DCC plug to the loco chassis. I used to carefully drill a hole in each chassis half, tap it to M1.6 and then use some screws to hold the wires in place to provide an electrical connection. However, I've now found that I can solder the wires directly to the chassis (having cleaned the area of paint/dirt) using 9% Phosphoric Acid liquid flux and 188 degree solder (both from Eileens Emporium). I've found I can do this without dismantling the chassis (but be in and out with the iron quickly to avoid damaging the plastic gears). The only other modifications is the removal of a tiny bit of plastic on the valve gear supports and fitting the rear pony truck (a radial truck on the prototype) along with a Dapol NEM pocket.
Not a straight body swap but nowhere near as difficult as it sounds above.
Atso-Cad Models
Atso
Re: Atso's new loco works - GNR Artic Coach question
Post by Atso » Wed Jan 17, 2018 7:37 pm
Hi all,
A question if I may. I've been working on the first class half of one of the pioneer articulated conversions but would appreciate it if anyone could clarify the arrangement of the roof ventilators. I assume that, above the compartments both the first and third class coaches would have the gaslamp tops along the centre line with a ventilator flanking it on either side.
Sorry to be asking but the Isinglass drawing is confusing regarding these details.
Edit: I've just noticed that I've posted this in my loco works thread - apologies...
Atso-Cad Models
BlythStationLad
Post by BlythStationLad » Sat Jan 20, 2018 12:17 am
Many thanks Steve. When will the body be available for sale?
Who is online
Users browsing this forum: Bing [Bot], Google [Bot] and 15 guests
