Atso's new loco works - now including my Hadley Wood layout build
Re: Atso's new loco works - now including my Hadley Wood layout build
Post by manna » Tue Sep 10, 2019 8:18 am
Of course there is, I had forgotten about the N1.
Atso
Post by Atso » Wed Sep 11, 2019 11:59 am
Indeed there is an N1 body print available in 4mm scale, and very nice it looks too!
I've done the initial test prints of the C12 and N1. Not quite perfect but pretty darn close.
Atso
Post by Atso » Thu Sep 12, 2019 5:53 pm
I've been spending some time working out the etched chassis arrangement for the N1. Still plenty more to do yet but I'm pleased with how this is shaping up.
john coffin
Post by john coffin » Thu Sep 12, 2019 6:11 pm
Steve,
given the curves in 2mm, you might find that separating the trailing wheels part of the frames from
the drivers, will be much more effective. I did it with my N1 in 4mm and it works well, the joint is
hidden behind the rear steps. The real things had a sliding axle, or a radial axle, so it is not cheating
too much .
Atso
Post by Atso » Thu Sep 12, 2019 6:19 pm
too much .
Hi Paul,
I have done so but hidden the arrangement behind the cab footsteps.
I've still to decide how I'm going to fix the rear end of the chassis to the body though.
Atso
Post by Atso » Fri Sep 13, 2019 10:56 am
I've done some more work on the chassis design. Just a few more bits to design and a couple of tweaks (i.e. clearance for the motor!) to make and I'll be ready to start thinking about converting the relevant bits into 2D artwork.
john coffin
Post by john coffin » Fri Sep 13, 2019 4:45 pm
Looks good, I made the mounting for the rear separate piece the mounting for the body, but since you I think
do not have an integral floor, that may be more complex for you , but it certainly works well in 4mm
Atso
Post by Atso » Fri Sep 13, 2019 7:57 pm
Thanks Paul.
You've correctly guessed that the loco does not have an integral floor (I've yet to work out the cab arrangements). I've attached bogies and ponies onto the bodies of locomotives before, I'm not a fan of this in N gauge - although that may well be because I've always adapted donor chassis in the past. Being the first time I've made a serious attempt at designing a chassis, I'm trying to keep things as simple as possible.
I'd love to see a photo or two of your N1 when you have a moment.
Atso
Post by Atso » Fri Sep 13, 2019 8:18 pm
Ok, other than sorting out lowering the joint for the front brake hangers a little (they attach over a fold line which isn't smart), and maybe removing a bit of the etch on the rear pony to ensure it can't short in the body attachment screw, I think the chassis is about as good as I can make it. Translating the 3D CAD into 2D will be 'fun'...
Atso
Post by Atso » Sun Sep 15, 2019 10:07 am
Some further work on the N1 chassis this morning resulted in the roughing out of some chassis weights.
I've left 0.5mm clearances all round so that nothing can short out and to generously allow for modest intolerance's in the internal dimensions of the prints. I'm toying with the ideal of 3D printing the weights and then casting them in white metal. The calculated volume of the weights is 3.22 cubic centimeters which would make them 33.35g in white metal (27.05g in brass). Having weighed up the loco body, wheels and motor, this would bring the theoretical weight of the N1 to between 44g and 50g, with most of the weight over the drivers; by comparison, the loco end of a Dapol A3 (minus bogie and cartazzi truck) weighs in at a little over 55g . Given that the rear radial truck will be a swinging bogie, I may revisit the bunker weight in the future as it may prove to be more of a hindrance than a help.
john coffin
Post by john coffin » Sun Sep 15, 2019 11:32 pm
Steve, think you should consider halving the weight over the trailing wheels, it might well overwhelm the loco
when travelling backwards. You can always add more weight as coal, if you find it necessary.
Looking good,
ps check your emails
Atso
Post by Atso » Mon Sep 16, 2019 8:25 am
Thanks Paul,
I think you're dead right about the bunker weight. Reducing it to half will knock 5g off the overall weight but will almost certainly result in a better balanced locomotive, which I believe is the desired outcome.
Email found and responded to. Sorry, I missed that one! :oops:
Post by Dave » Mon Sep 16, 2019 9:47 am
Really nice work as usual and interesting.
I like cad drawing, but I must start and learn a new programme, the 3d modelling programme I use
at work is no good for model railways as I found out.
Atso
Post by Atso » Fri Nov 15, 2019 7:36 am
While waiting for sufficient funds to get some things etched, I've turned my attention back to an old project, the J6s.
The problem for me was that the Farish J39 donor was longer than the J6 and the resulting stretched loco body ruined the overall look for me. Therefore, taking inspiration from Mr King, I gave matters some thoughts and got out my piercing saw and started cutting things up.
First the unaltered donor chassis.
And after some cutting and joining had been performed.
The parts have been joined using epoxy glue and pinned together using some M1.2 self tapping screws, while the coupling rods are B1 spares. Amazingly, everything still works!
Post by Atlantic 3279 » Fri Nov 15, 2019 11:08 am
Encouraging when things work out, isn't it?
