Oxford Rail N7
Oxford Rail N7
Amongst the latest offerings from Oxford Rail is an N7 in GER, LNER and BR liveries plus sound equipped versions too.
http://www.oxforddiecast.co.uk/collecti ... -or76n7002
Re: Oxford Rail N7
add that to the list of locos I never thought would get made any time soon
Re: Oxford Rail N7
All I can say is lets hope they do some proper research before they tool the N7 up.
Re: Oxford Rail N7
Yes, it would be unfortunate if the chimney was always on the left no matter which side you were looking at.
Re: Oxford Rail N7
Sufficient differences across the various lots constructed and over time that this could be a minefield for Oxford Rail unless they consult known authorities (e.g. Lyn Brooks, Locomotive Co-ordinator of the GERS who advised Hornby on their various GE models) given the fuss over some fairly simple wagons.
Personally I'd be more accepting if it was a Bachby production, preferably Hornby.
Re: Oxford Rail N7
The problem is that when a model is produced it closes the market for a better model for some time.
Re: Oxford Rail N7
Then again, there are probably in excess of 30 other LNER 'small black loco' classes, equally deserving of a RTR model on grounds of numbers, ubiquity and endurance in service until the final decade of steam operations in their area; so any other manufacturer has plenty of alternative choices when looking to offer an LNER loco subject?
Possibly I am wildly optimistic, but with the most recent wagon release being decidedly better than what came earlier, OR do seem to me to be moving up the learning curve.
Re: Oxford Rail N7
Forgive me, I don't really follow what they release - which one was that?the most recent wagon release being decidedly better
Re: Oxford Rail N7
The LNER six plank general merchandise open. Correctly dimensioned and looks right. Error in the brake gear, but since it is clip fit this is ten minutes tops to sort out. You can bevel the inside of the tops of the doors to ice the cake if not planning to tarp it once running on your layout.
Deserves acknowledgment I feel. Firstly, an excellent subject choice (Oxford could only have gone one better by selecting the LMS equivalent, for an even more numerous grouping and BR steam period wagon that has never had a RTR model in OO) and executed decently. The longer established - and by this factor much more experienced - competitors have managed recent wagon releases that have larger deviations from the truth: without exciting wild criticism.
Re: Oxford Rail N7
Indeed they have, and it's a practice that goes back at least as far as the much vaunted Hornby Dublo SD range.Hatfield Shed wrote:. The longer established - and by this factor much more experienced - competitors have managed recent wagon releases that have larger deviations from the truth: without exciting wild criticism.
Ian Fleming
Re: Oxford Rail N7
Can only share 65447 caution re this announcement with varieties of boiler, safety valve cab side windows, cab roof, bunker, chimneys etc.65447 wrote:Sufficient differences across the various lots constructed and over time that this could be a minefield for Oxford Rail unless they consult known authorities (e.g. Lyn Brooks, Locomotive Co-ordinator of the GERS who advised Hornby on their various GE models) given the fuss over some fairly simple wagons.
ORs announced intentions are:- GER 1002, LNER 8011 and 'E9621' in 'early BR'.
Yeadon 27 and 'Green book' 9A are also important references.
1002 was turned out in GER grey in June 1921 to Jan 1925 when it went under LNER black. Only 1001 carried blue and had its dome in a different position to the 1921 series.
LNER 8011 was so numbered in October 1925. If OR use the same body as 1002 then it is valid to Jan 1937 when it lost its condensing gear.
BR (E)9621 is the engine eventually preserved although I cannot find reference to an 'E' prefix. Given a N7/4 boiler with round topped firebox when still numbered 7999 in February 1946, it was numbered 9621 in Jan 1947 changing to BR 69621 in January 1949.
Since this is the only surviving version available for scanning one hopes OR respect the differences between these engines when they go into production. I would be happy to pay more than the published price to obtain an accurate LNER version.
Re: Oxford Rail N7
And those are only for startersPhil wrote:Can only share 65447 caution re this announcement with varieties of boiler, safety valve cab side windows, cab roof, bunker, chimneys etc.
But the point is that some were dependent on the original construction lot features; so far the OR choice appears to be restricted to those Stratford-built and classified by the LNER as N7/GE.
Re: Oxford Rail N7
I have already made this point elsewhere. Possibly the most difficult feature to modify would be the cab windows. The numbers quoted related to the 22 built to the GER standard not the 112 subsequently built to the revised LNER standard. At least Iain Rice showed how it could be done many years ago with a Finecast kit. I wouldn't want to go there with a new RTR model.
