LNER Teak colour paint
Graeme Leary
Post by Graeme Leary » Mon Feb 05, 2018 3:00 am
Finally, about to paint my Restaurant triplet and as we have a limited range of paint brands available in New Zealand would appreciate any comments on the nearest colour from either the Humbrol or Tamiya range which we can get here. (I also have a bottle of 'Dark Earth' from the Hobby Colour range which looks very close. (I had originally been advised that Railmatch Teak is ideal but unobtainable here).
And (opening up a can of worms now) what is the general consensus acrylic v. oil and satin v. gloss for the best finish)?
I've also had a comment about 'using water based varnish' (gloss) before applying transfers but have not come across this before. Again, is this a product readily available in the UK but maybe not here?
Many thanks.
Graeme Leary
Ocean Swell
Re: LNER Teak colour paint
Post by Ocean Swell » Mon Feb 05, 2018 8:08 am
Hi Graeme,
I have used a vallejo water based varnish (model air) and was happy with it vallejo do a large range of paints not sure which is best for teak though. A quick google shows it is available in NZ.
https://www.acornmodels.co.nz/products/ ... -material/
Post by jwealleans » Mon Feb 05, 2018 9:30 am
Graeme,
I did a step-by-step on the way I produce my teak finish here. I use mainly Humbrol paints with the odd car aerosol.
For varnishing I use Johnson's Pledge floor polish (what was Klear) which is acrylic and brushes on. I'm sure other gloss or satin varnishes would be just as good.
earlswood nob
Post by earlswood nob » Mon Feb 05, 2018 10:55 am
Wilko do a range of wood coloured varnishes, including teak.
When diluted, they spray quite well, or they can be brush painted.
They are cheap and a can should last forever.
notascoobie
Post by notascoobie » Mon Feb 05, 2018 3:51 pm
Hi Graham.
I tried various methods for teak over the years but a couple of years back I started experimenting with acrylics. Initially I used Vallejo colours but then moved to artists acrylics. The quick drying time was the attraction but that means you have to have everything ready then work fairly quickly. The paint is applied sparingly in the direction of the grain. 2 coats of differing colours are applied and topped off with quick drying teak colour varnish. I then use Klear floor polish to seal it all in with the transfers. I use acrylic medium to thin the paint slightly and to keep it workable.
The method is still evolving but at the moment it's as follows. First a white primer coat. Next I mix yellow ochre with golden ochre approx 60:40, then a coat of raw sienna mixed with burnt sienna 75:25. Then it's teak varnish and finishing.
I hope that helps. Regards, Vernon
This shows how the finish is built up
A 4mm example
7mm scale
A 7mm scale example prior to finishing
Graeme Leary
Post by Graeme Leary » Mon Feb 05, 2018 9:32 pm
Thanks all, gives me plenty of options to work on. Fingers crossed.
Graeme
JASd17
LNER P2 2-8-2
Post by JASd17 » Mon Feb 05, 2018 11:03 pm
Graeme,
Look up Mike Trice's posts here and on RMweb too.
All good stuff.
As to 'teak' paint for metal solebars and headstocks etc. That is another subject.
Post by Woodcock29 » Tue Feb 06, 2018 12:57 am
Hi Graeme
I would recommend what Jonathan Wealleans has set out in his thread as referenced above. Its very similar to what I do - he uses more colours. I mainly mix my browns using existing Humbrol colours and add orange as well into the brown mix. The important thing is to get variation between panels as you would from wood from different trees. Being in Australia I can generally only get Humbrol paint - I use only oil based paint.
The top photo is a D&S exGN Howlden brass kit I did a couple of years ago. This is unlined and meant to present a coach that has weathered over time but not yet been painted plain brown. The lower photo is a Kirk kit I built back in the 1980s. Both use the same basic painting technic. The Kirk has been varnished with gloss Humbrol varnish. The subtle yellow lining on the Kirk is achieved by scraping the paint off the beading where appropriate as the plastic was yellow coloured.
Andrew Emmett
JASd17
LNER P2 2-8-2
Post by JASd17 » Tue Feb 06, 2018 2:25 pm
Andrew I particularly like the Howlden model with all the gas pipe detail on the roof.
Post by Woodcock29 » Wed Feb 07, 2018 1:13 am
Thanks John. I have a heap more Howlden stock to build but need to find the time amongst all the other projects!
Next will probably be a twin from two of Frank Davies Dia 134 luggage lavatory composites and then a triplet from 3 of Dan's kits.
Graeme Leary
Post by Graeme Leary » Fri Feb 09, 2018 11:51 pm
Again, thanks for the additional posts, all noted.
In our small town we have a newish model shop (hallejulah, one opening, not closing!) and the owner has shown me his technique to do wooden propellers on vintage model aircraft, plus some floor planks he's done for a display - if I can replicate this for the teak coaches I'll be a very happy chappie.
Graeme
JASd17
LNER P2 2-8-2
Post by JASd17 » Sat Feb 10, 2018 10:26 pm
Graeme,
If the 'floor planks' are in open wagons or mineral wagons, the interiors would not have been painted or varnished at all, just weathered wood.
I do think the railway hobby has something to learn from other genres in respect of weathering, not least military modellers.
Hope to see you soon.
JASd17
LNER P2 2-8-2
Post by JASd17 » Sat Feb 10, 2018 10:36 pm
As a general point on 'teak' finish, I was speaking to Vernon 'notascoobie' at the Doncaster Show today. He said the effect he was after was rather less weathered, being a GNR period modeller. A more red overall colour, as opposed to slightly duller brown.
We agreed these are very subtle and to a certain degree subjective variations of technique.
Graeme Leary
Post by Graeme Leary » Thu Mar 01, 2018 2:22 am
Just about there but need some advice on the matter of linings on teak coaches.
My restaurant triplet kit will be running with 6-7 Hornby coaches; 3 or 4 from their older R477/9 series, 2 of the R4332 (later I understand) range and the most recent R4530A (the Full brake). Quite different finishes especially between the R477/9 series and the R4530A but I'm working on the basis that in reality the teak will have weathered to various degrees over the years so therefore acceptable.
However, these are all lined (in 'yellow') and I presume the Restaurant triplet is also finished this way but someone once suggested the triplet may not have been and I'm unable to unearth any colour photos of the triplet to be sure myself. However, if they are I have some colour photos I've taken of a restored teak buffet car either at Pickering or possibly Bridgenorth and these show the lining to be quite bright and also no linings on the vertical bands between the word 'Buffet' and 'Car'. I presume the same would apply on the Restaurant cars ie there would not be linings on any 'bands' that crop up between any letters of the words 'Restaurant Car' on the lower horizontal panels.
Thanks again (and looking good so far thanks to many of you).
Graeme
Post by jwealleans » Thu Mar 01, 2018 6:44 am
The triplet would certainly be lined, Graeme. You've correctly picked up on the small detail of the unlined beading between the two words of the branding. The only other area where there is some uncertainly is the lining on the vertical beading directly adjacent to windows - some photos show this, some don't and up to now I haven't read or heard any hard and fast guidance on when it should/shouldn't be applied. I don't usually apply it (although I have on the D10C below) but I'd suggest you do whatever matches the rest of your set.
Note that the HMRS lettering is too large and only just fits between the beading in the lower panel.
