Oxford Rail N7
Re: Oxford Rail N7
Could someone who has a BR version of the Oxford N7 please measure the height of the chimney, dome and safety valves for me?
Re: Oxford Rail N7
In that order, 7.8mm, 8mm, 5.5mm (from top of smokebox for the chimney, top of boiler for the dome and valves). That's the BR early crest 69612, which came in a box as 'early BR' E9621...
Re: Oxford Rail N7
Some one on the Dark Side posted yesterday that they are too high?.
Re: Oxford Rail N7
Thanks Hatfield Shed. As I thought from viewing photos they are too tall. The chimney should be 6mm (1'6") and the dome and safety valves 7.2mm and 4.1mm respectively based on the Isinglass drawing.
Re: Oxford Rail N7
Strange to relate, my better Wills kitbuild for a late 1950s N7 has boiler fittings of those dimensions.
It may just be coincidence, but the OR model's fittings are dimensionally practically identical with those on the Roche drawing of GER 1005. Whatever, I shall mangle it into BR condition form in due course.
Re: Oxford Rail N7
Surely someone has a proper engineering drawing, as opposed to a Roche, or indeed one of John Edgson's?
- LNER Thompson L1 2-6-4T
Re: Oxford Rail N7
I see Rails Of Sheffield now have the GER version with sound fitted in stock. Has anyone any experience with the sound fitted version and can they share any opinions regarding the sound. Obviously there is a massive saving on the cost of having a high end sound decoder fitted but are you paying for that by compromising on the sound quality?
I'd be interested to know any thoughts.
Re: Oxford Rail N7
So I guess no-one has purchased a sound fitted example.
I'll let you know what mine sounds like when they eventually get around to releasing the version I have ordered, over a year ago!!
