0-6-0 saddle tank
kimballthurlow
0-6-0 saddle tank
Post by kimballthurlow »
I purchased a brand new Electrotren HO scale tank engine from a dealer in Germany (bwbahn.de), and it was only 34.99 Euros, which seems terribly cheap.
Maybe others might be interested to bash the mechanism for any LNER or constituent loco of similar wheel arrangement.
Model is product code E0042, and I can provide major dimensions for anyone interested.
Kimball
65447
Re: 0-6-0 saddle tank
Post by 65447 »
So why not be really helpful and provide the wheelbase and wheel diameter etc. in your original post?
Dave S
Post by Dave S »
kimballthurlow wrote: Sun Apr 15, 2018 10:22 am Model is product code E0042, and I can provide major dimensions for anyone interested.
Kimball
Yes please. Wheels and wheelbase.
Out of interest What's the motor?
Other questions might include things such as where's the motor, how does it run, how deep are those wheel flanges, is the BTB suitable and can it be adjusted if necessary.
If it's HO it might be small enough to go under a J62 body...
4812
Post by 4812 »
I've no other information but, apart from the closed-in cab sides and the mini-bunker, this loco looks remarkably like Sharp Stewart 2927, built for Spain. There is a picture on Page 8 of 'British outline locos overseas' on the RM site.
kimballthurlow
65447 wrote: Sun Apr 15, 2018 1:46 pm So why not be really helpful and provide the wheelbase and wheel diameter etc. in your original post?
Because 65447, I don't have the time to be helpful unless you are interested.
It is a public forum and others have shown a courtesy in asking, so here we go:
Made in China - with NEM coupler receptacles.
Die-cast chassis, with die-cast boiler weight in a plastic body shell.
  • Wheelbase front to rear 20.4 and 23.7mm.
  • Coned wheel diameter at face 13.8mm.
  • Depth of flange 1mm.
  • Back to back 14.2mm. Not sure about adjustment.
Motor is a simple open frame drum commutator type, permanent magnet, 3 pole armature.
The motor drives the front axle by a brass worm on a plastic gear. There is no flywheel, but the worm is substantial.
Runs very sweetly, but I did not test start voltage etc, as I don't have the tools.
Picture of motor. Note the 6 pin decoder receptacle.
Kimball
Last edited by kimballthurlow on Wed Apr 18, 2018 3:20 am, edited 6 times in total.
kimballthurlow
4812 wrote: Sun Apr 15, 2018 3:37 pm I've no other information but, apart from the closed-in cab sides and the mini-bunker, this loco looks remarkably like Sharp Stewart 2927, built for Spain. There is a picture on Page 8 of 'British outline locos overseas' on the RM site.
Hi 4812,
Thanks for that information.
Appendages which could be fabricated from sheet or bar steel were often added at the destination.
regards
Kimball
Many thanks for the details.
Dave S
Post by Dave S »
Thanks for the info.
If I've worked that out correctly it's
5' 1 1/4" - 5' 11 1/4" for the wheelbase with a 3' 11 1/4" wheel.
kimballthurlow
Dave S wrote: Mon Apr 16, 2018 9:35 am Thanks for the info.
Hi Dave,
At 1:76, you are correct on the wheelbases, but 6" over on the wheel diameter.
By my calculations the wheel is 3' 5 1/4".
regards
Kimball
Dave S
Post by Dave S »
kimballthurlow wrote: Mon Apr 16, 2018 11:41 am Hi Dave,
regards
Kimball
I am....what a muppet...I think I can see where I made a schoolboy error..
Unfortunately a bit short in the front wheelbase department to suit use under a J62, and that motor is clearly too broad to hide properly in the fully exposed lower part of the width of a small boiler on a saddle tank engine - as is evident from the slab sides added to the enormously long firebox portrayal on the Electrotren body moulding. A pity - although it might do under a J63 if the wheelbase were ignored. I already have a full kit for a J63 though.....
Can't win 'em all.
DS239
Post by DS239 »
The chassis would be 'near enough' for a J88, I would think..
kimballthurlow
Thank you Dave S, Atlantic 3279 and DS239.
My original purchase of this locomotive was motivated entirely by the price, due to its being shipped with another item which I wanted.
I don't model Spanish railways, though I can use this with other European stuff.
Its likeness to British engines appealed to me, and this possibility has been confirmed by 4812.
(Can a possibility be confirmed?).
Anyway I appreciate the interest shown and observations made, and I hope someone can make use of the information.
Kimball
Last edited by kimballthurlow on Thu Apr 19, 2018 12:22 am, edited 1 time in total.
with a bit of work, a handy little industrial loco could appear.
