G-Train Locomotive Works / Graeme King Joint Venture - GCR/LNER 4-6-0s - B3/1 & B7 available; B3/2 in progress
- GNR J52 0-6-0T
Re: G-Train Locomotive Works / Graeme King Joint Venture - GCR/LNER 4-6-0s - B3-2 & B7 to follow
10411 2 LNER GCR 2) GA of 4-6-0 passr engine B3 Class GC/LNE
I got this from the NRM back in 2014 - it is still on their lists.
I also have the B7/9Q from MOSI but this has to be stitched together since is comes in around 70 blocks
A useful reference, thank you.
The kit makes up very well for the motion bracket and slide-bars, but it is a bit fiddly!
If anyone can produce a good clean GA of the 9P, I would be happy to pay costs. The drawing in Johnson’s book is very frustrating to try and interpret.
Tim
Tim
Tim,
If it is what is what rather than dimensions you are trying to get your head around, if you have not already done so,
then you could do worse than look at the close up of the 9Q on p105 and the part-dismantled 9Q on page 118 of EM Johnson's book.
Simon
Simon
I have scanned the MOSI drawing in Johnson vol.2 and can zoom in well enough to read at least some of the measurements, but a clean GA (and its related drawings) would be better. At the time when I bought the 9Q GA (excellent as a full-res colour digital download, by the way) from SSPL, I did ask the image licensing officer at the Science Museum Group if he could help me track down the 9P one, and he said he would ask his colleague about availability. Not had any comeback so far.Tim Watson wrote: ↑Sun Jun 30, 2019 10:15 pm....If anyone can produce a good clean GA of the 9P, I would be happy to pay costs. The drawing in Johnson’s book is very frustrating to try and interpret. ...
In the meantime, the Brassmasters inside motion etches (plus some ex-Finney brass eccentrics out of the T9 kit) have arrived and now begins the head-scratching process of tailoring the etch parts to fit. The ex-Finney eccentrics speak for themselves and are easy to use, but the lead axle crank webs - which are also circular - are not much bigger and I can see a fine old time trying to either:
1. adapt what are etched eccentric cams into cranks! or
2. use the T9 cast brass cranks, but severely reduce the webs (which are massive) to something approximating the 9P/B3 shape.
The B3/1 frames have been marked out for CSB pivots using the suggested measurements given on the CLAG website, with one drill bit snapped so far to show for it.
I know it’s not the purist’s way, but why not simply drive the internal valve gear from the Finney eccentrics, with rockers connecting to the outside cylinder valves, as per the kit. You simply won’t see the internal pistons, crossheads & con rods working, as they are at the bottom of the frames.
I have represented the top of the internal valve gear on my engine, but I doubt that making the outside valves move will be particularly visible, tucked up under the valance with the drain cock linkages in front.
Tim
Tim
To wear, or not to wear the hair shirt, that is the question....
Tim Watson wrote: ↑Tue Jul 02, 2019 7:41 am I know it’s not the purist’s way, but why not simply drive the internal valve gear from the Finney eccentrics, with rockers connecting to the outside cylinder valves, as per the kit...
I had considered this, but......
.....there is so much open space between the frames in that area that to me it seemed a shame not to try to fill it. In a way, I blame Graham for designing in the partial valve gear with "short-cut" eccentrics in the first place, and I thought why not just go the whole hog? The drawings for it sort-of exist........You simply won’t see the internal pistons, crossheads & con rods working, as they are at the bottom of the frames.
It's not because I want to. I have to.Atlantic 3279 wrote: ↑Tue Jul 02, 2019 8:49 am To wear, or not to wear the hair shirt, that is the question....
Been a while since any last update, however things are happening in the background. As you will have seen from Graeme's (3279) thread, there is progress towards bringing the self-trimming tender etch to market and my New Year's resolution is to crack on with the B7 and B3-2 test builds.
In the meantime, thought you'd like to see this, courtesy of Tony Wright's camera at the Southampton show:
The prototype build has returned from the paint shop (Ian Rathbone) and is seen here posed on Grantham's turntable.
That is a very fine locomotive.
Tim
Tim
Thanks Tim, that's very kind coming from someone like yourself. It is certainly pleasing to see it turn out like that after ... well, something like two years in the making.
VERY much looking forward to seeing the 2mm version once complete and following your build of that with a mixture of awe and fascination.
No resting on laurels though - must crack on with the B7 test build as best I can.
Absolutely beautiful, reminds me that there is much room for improvement in my own model-making skills.
Thank you for sharing it with us.
Paul.
Paul.
Drooling here. Mine is, sadly, still in its box waiting for me to get around to it. But hey!- this Christmas just gone I received a building jig, now just wheels, gears and motor to source and then I can make a start.
A magnificent beast!
Drooling factor? 10 out of 10
Very kind!
(Remainder of original post was wrongly place here and has now been relocated)
