Hello there
I wondered if anyone out there can help me? I am hoping to find someone who can tell me what trains ran on the old Honington to Lincoln branch line from the 1930s to the very early 1960s untill it closed. The branch line started at Honington and it ran off the Grantham to Lincoln line.
Thank's
Photoman
- NER Y7 0-4-0T
- LNER N2 0-6-2T
Re: Honington to Lincoln branch line
Served by both Grantham/Boston and Grantham/Lincoln services, typically 24 workings per weekday.
- LNER Thompson L1 2-6-4T
I assume this is the line you are referring to, there is information out there, just put 'Honington Ironstone Sidings' into Google.
You might find this an interesting starting point:
http://www.tracksthroughgrantham.uk/rai ... ne-trains/
Obviously it was a GNR line pre grouping so that helps to narrow down the appropriate rolling stock.
Here is an interesting book all about the line published by Oakwood.
Iron Duke
This topic is already under discussion following an initial question at:
viewtopic.php?f=5&t=12979
Presumably it is more appropriate to continue the discussion there, under one heading, as this is not (yet, as far as I know) a model railway matter, but do correct me if I'm wrong.
