I'm renaming a Gresley A 3.
DonnyRailMan
Location: White Rose County Gresley & Peppercorn Country
Post by DonnyRailMan » Tue Nov 06, 2018 12:39 pm
I plan to rename a Gresley A3 with a fictitous name and number in B R Green.
I thought about giving it the number 60144 or 60115 but then thought
would that number have already been given to a B R Locomotive.
Dose anyone know of them two numbers being used by B R ?.
Instagram @severncrescentrailway
DonnyRailMan Instagram @severncrescentrailway
giner
Re: I'm renaming a Gresley A 3.
Post by giner » Tue Nov 06, 2018 3:40 pm
You'll have a bit of a job fitting in any A3 alternative number. A4's ended at 60034, A3's started at 60035 and ended at 60112. Following that, the A1's started at 60113 all the way up to 60162, after which the more recently built 60163 was added.
Your chosen 60115 and 60144 were both A1's.
DonnyRailMan
Post by DonnyRailMan » Tue Nov 06, 2018 8:49 pm
Thank you for the information giner.
giner
Post by giner » Wed Nov 07, 2018 12:19 am
You're welcome, Donny. BTW, what name did you pick? Plenty of racehorse options available on that.
Just a thought, but if you were to do your A3 in pre-nationalisaion livery, you would have some choice of numberings. Rather than spelling it all out, as it can get quite convoluted, can I just refer you to this page: https://www.lner.info/locos/A/a1a3a10.php
Scroll to the bottom and check out the LNER numbers column.
Seagull
Post by Seagull » Wed Nov 07, 2018 2:01 am
You could use 60113 for a fictitious pacific, I'm sure that there was a bloke called Thompson that did the same :D
Alan
giner
Post by giner » Wed Nov 07, 2018 4:14 am
Ouch! :mrgreen:
DonnyRailMan
Post by DonnyRailMan » Wed Nov 07, 2018 12:12 pm
Hi giner, thank you again for your help . The name will be a personalised one I have chosen.
It is just a number I am looking to go with the A3 in B R Green I have thought about 600103.
LNER P2 2-8-2
Post by Hatfield Shed » Wed Nov 07, 2018 12:31 pm
Personally, I'd opt for 60101. One of the most anonymous of the class with a name (sadly) unlikely to mean anything to most people.
DonnyRailMan
Post by DonnyRailMan » Wed Nov 07, 2018 3:28 pm
Alan
From what I have read and heard he was as popular as Mr Beaching LOL.
giner
Post by giner » Wed Nov 07, 2018 3:45 pm
Never copped that one 'in the flesh', always seemed to be stuck up norf. When I see the name, I always think Chicago.
giner
Post by giner » Wed Nov 07, 2018 3:47 pm
Good luck with the job. Hope you'll post a pic when you're done.
DonnyRailMan
Post by DonnyRailMan » Wed Nov 07, 2018 3:53 pm
Thank you and yes I will post photographs when Gresley A3 ********* number ****** is running.
If you are on Instagram I have a page with my collection on, see below.
DonnyRailMan
Post by DonnyRailMan » Wed Nov 07, 2018 3:55 pm
Hi Hatfield She'd, I thought that number was Great Northern number in B R days.
LNER P2 2-8-2
Post by Hatfield Shed » Wed Nov 07, 2018 5:24 pm
'Great Northern' - as already mentioned above - was BR 60113.
Whereas BR 60101 carried a name which is largely forgotten, and as a result many (perhaps most) would accept an alternative well chosen name without demur.
giner
Post by giner » Wed Nov 07, 2018 7:30 pm
Yes, the name Cicero doesn't remind me of a racehorse. That's why I mentioned Chicago. Cicero is an area of Chicago. :)
