Corridor tender for blue A4 Mallard ?
52D sub shed
Post by 52D sub shed »
Hello,
I would like to change the tender on Hornby's Mallard for what I believe would be the correct corridor type to head the Coronation set.
It would be preferable not to have to respray the replacement, I did wonder if the tender on the Great British Locomotives Mallard could be adapted without to much surgery.
Could one or more of my "invisible friends" as the wife calls you chaps advise please?
cheers
Geoff
Atso
Re: Corridor tender for blue A4 Mallard ?
Post by Atso »
Hi Geoff,
I believe that Mallard retained a non-corridor tender until 1948 so a corridor tender would be incorrect for the LNER period. I don't believe that Mallard was one of the locomotives rostered for the regular Coronation service but hopefully somebody with more knowledge than I will be able to confirm or disprove that.
DonnyRailMan
Location: White Rose County Gresley & Peppercorn Country
Post by DonnyRailMan »
Hi Geoff,
The information that Atso as posted is the same as i was given sone years ago, when i asked the same questne.
DonnyRailMan Instagram @severncrescentrailway
52D sub shed
Thanks for taking the time to reply folks, I guess there is more to this than I imagined.
Atso
Post by Atso »
Baron von Shields wrote: Thu Nov 22, 2018 3:07 pm Thanks for taking the time to reply folks, I guess there is more to this than I imagined.
I believe that the Coronation A4's typically had a chrome trim strip along the bottom of the valances and tender and stainless steel numbers/letters. However, I'm sure that there were occasions when the train was hauled by another A4; the Silver Jubilee set certainly did (and not always an A4!). However, I appreciate this doesn't necessarily help with regard to Mallard.
sawdust
Post by sawdust »
Did A4's used on the West Riding Limited require corridor tenders?
Sawdust.
52D sub shed
Come to that did the Coronation require corridor tenders as they appear to have undertaken a crew change at Newcastle?
