ACFI water feed heater conversion kit available in 4mm/00 Gauge for Hornby A1/A3 model - Niu Models
Posted: Thu Jul 18, 2019 2:06 pm
My ACFI water feed heater kit, as fitted to 'The White Knight' and 'Shotover', is now available.
The kit is in 4mm/00 Gauge and is designed to fit the current Hornby range of loco drive A1s and A3s, and is shown in the photos below fitted to Hornby's 'Book Law' model.
The kit includes the ACFI pump, ACFI support bracket, zenith separator, boiler feed clear and smokebox mixing chamber. It also come with a pair of etched nameplates for which ever loco you choice.
Brass rod (1mm, 0.8mm, 0.5mm) is required to for the pipe work along with two small bits of 0.25mm plasticard for the smoke box flanges.
The kit retails at £19.50 + postage.
To order email Niu Models at niumodels@gmail.com.
