Ian Kirk push pull autocoach
Daryl
Post by Daryl » Fri Aug 02, 2019 8:36 pm
I’m just about to start building the Ian Kirk 4mm kit of a push-pull autocoach.
I have a few questions if anyone can answer them.
What prototype is the kit based on
In BR days circa 1960 what livery did they carry
Was there seats inside or benches
We’re the seats/benches in the compartment behind the cab along the side of the carriage or across
Possible serial numbers and location on the carriage
Am I correct in thinking the kit is based on the Epping and Ongar push pull coaches
65447
Re: Ian Kirk push pull autocoach
Post by 65447 » Sat Aug 03, 2019 5:14 pm
The Dia. 64 or 65 4 compartment Brake Third, converted around 1940. The difference between the two diagrams was 3" in the overall width, not noticeable in 4mm scale. In all 7 were converted, of which 2 were allocated to the GE Section - post-1943 nos. 86058 and 86135
The stock was withdrawn in 1959 still in Crimson livery
The 4 compartments had 4-a-side seating the full width of the compartment
See above for numbers, which were located as follows:
With the driving cab to the right - centrally in the upper panel under the driving side window to the right of the door, which was marked DRIVER.
With the driving cab to the left - centrally in the upper panel below the RH window to the last compartment on the right.
Yes
There are a few other points to look out for, in addition to the standard carriage ends - both ends had doubled up electrical connections, as did any adjoining carriage in the set, whilst the bunker of the Push-Pull fitted tank engine had one set. These were to carry control signals. These was also a control gear box below the end windows and a pair of horns above.
I'll PM you some additional details.
Daryl
Post by Daryl » Sun Aug 04, 2019 6:26 pm
Hi Mike,
Excellent, thanks for the info, I've read your PM but can't reply as apparently I need to partake in more topics before this feature is authorised!
65447
Post by 65447 » Tue Aug 06, 2019 9:04 am
Hi Mike,
Better get posting then... :)
