Vernon's Workbench
- notascoobie
Vernon's Workbench
I've put bits and pieces of mine on here before but not under a generic title. Although I'm quite busy I doubt this thread will move along too quickly.....
First up, I'm on with a Tourist Stock Twin Third in 7mm scale. It's from a Newbold kit and has gone together really well. The only problem I had was inducing the tumble home. I'm a fan of the "broomstick method" and I had to use enormous force to get the curve in there.
Now I'm down to detailing. Body protection strips, buffer housings, lamp brackets etc.
Now I have a question for our resident experts were there "normal" jumper cables between the 2 carriages of the set or were they connected at buffer beam level or something like that? The nature of the beasts means the photos tend to be oblique and you can't see. Also, the Isinglass drawing sheds no light. Any help/advice much appreciated. Thanks.
Vernon
Vernon
- greenglade
Re: Vernon's Workbench
looking good Vernon..
Pete
Pete
- notascoobie
I forgot to mention it's got Kemilway bogies. Abslutely beautifully designed but they are rather complex and take forever to build.
Vernon
Vernon
Do you not have a rolling millnotascoobie wrote: ↑Mon Mar 16, 2020 3:03 pm.... The only problem I had was inducing the tumble home. I'm a fan of the "broomstick method" and I had to use enormous force to get the curve in there....
- notascoobie
Thanks Pete
- notascoobie
[/quote]
[/quote]
Hi Ivan.
I have rolling bars that will do 7mm loco boilers but they're not big enough for a carriage side. It's the first time I've struggled using my length of wooden curtain rail. I got there but it was hard work.
V
[/quote]
Hi Ivan.
V
Vernon I have found this in an excursion circular for the GN Section in early 1932, not sure it quite answers your query:notascoobie wrote: ↑Mon Mar 16, 2020 3:03 pm
Annoyingly, there's a clear photo in Harris' book showing a Coronation articulated pair at assembly, and it affords no clue whatsover!notascoobie wrote: ↑Mon Mar 16, 2020 3:03 pm ...were there "normal" jumper cables between the 2 carriages of the set or were they connected at buffer beam level or something like that? ...
I would apply reason to this. Brake pipes and heating terminated on bufferbeams. I would expect special short pipes were provided between articulated vehicles as the 'bufferbeam' was still present above the articulating bogie.
- notascoobie
Thank you very much for the observations and the photo. I've not applied any intra-setjumper cables yet. I'm still hoping there's a definitive photo somewhere.
Vernon
Vernon
Good luck. Considering that the Quad Arts survived to 1966, there must be living railwaymen who can provide reliable information on this matter. Definitely worth sharing here if anything 'surfaces'.
- Dave
Vernon.
I have found a drawing which shows the connections on the triplet restaurant cars.
I assume this will be a standard arrangement. My new laptop will not accept my version of photoshop, so I will post when I get my old laptop working as the jpg is too large to post.
The connections are either side of the ends, one each side about half way up with cables running down to the sole bar through another box at low level.
- notascoobie
Hi Dave,
I'd love to see the drawing. I'll look forward to you posting it. Thanks.
Vernon
Vernon
- Robpulham
They look rather nice Vernon, when I get around to mine I will hopefully remember to note the tumblehome/turn-under difficulties.
I bought mine second hand of Dave Sweetland (he designed them for Newbold) and they came with some quite detailed cast bogies - or at least I thought so at the time but I haven't had them out of the box for a couple of years or so.
Hi Dave,Dave wrote: ↑Sun Mar 29, 2020 4:13 pm Vernon.
Which version of the Triplet is that?
I have sent Vernon a photo of electrical connections between carriages in a Quad set, built in 1924. Therefore well before through lighting was a standard fitting.
I know logic and the LNER is a dangerous thing to count on, but surely the cables and sockets between electrically lit articulated stock would have formed the basis of a design for through lighting?
The 1924 cabling does not appear very different to the later set-up. In 4mm at least it would not be. I am sure 7mm requires that bit more information.
- notascoobie
Thanks for the kind worRobpulham wrote: ↑Sun Mar 29, 2020 8:57 pm They look rather nice Vernon, when I get around to mine I will hopefully remember to note the tumblehome/turn-under difficulties.
ds Rob. I've got another twin 3rd to build plus a brake third and a buffet car. I reckon a non corridor teak break will complete a nice set for an Atlantic or D2 to haul.
I got mine second-hand off a guy in France who was downsizing. He'd got in Kemilway bogies for the twins and Sidelines bogies for the others. Plus some beautiful heavy wheelsets and Isinglass drawings for all. All I need to do is apply elbow grease and solder!
This lock down means plenty of modelling time!
Regards,
Vernon
