Hi all,
This is the first time I have used a forum, and also a newbie at OO railway modelling! I am attempting to re-create a model of Sunilaws station on the now defunct Tweedmouth to Kelso branch line. Although the station house still exists, (as a private residence), I would like to know if it is possible to obtain drawings of the original, to scratch build from. Is it possible to obtain station plans, and if so where would I search?
Any help would be gratefully received.
Warkster
Station Plans
Re: Station Plans
Try the website of National Library of Scotland for old edition large scale OS maps revealing the station layout. You can zoom in to get quite a lot of detail.
What you choose to do, or not to do, with the print-screen key on your computer is a matter for your conscience, with due regard for legal and ethical considerations.
Re: Station Plans
I'm currently in the process of moving to Kirk Yetholm, I did initially look at a couple of properties in nearby Wark and noted the location of Sunilaws. I've been making a mental note of the closed and abandoned stations and lines to visit and walk and that is on the list.
Re: Station Plans
Hi, thank you Atlantic 3279, I'll try the Library of Scotland as you suggest.Atlantic 3279 wrote: ↑Thu Dec 10, 2020 10:06 pm Try the website of National Library of Scotland for old edition large scale OS maps revealing the station layout. You can zoom in to get quite a lot of detail.
Re: Station Plans
Hi Thanks drmditch, I have used the Disused Stations website in my early research, it is very good. If all else fails, I will have to scratch build from some of the images like the ones on the DU website, plus from the remaining private residence.
Re: Station Plans
Hi Dave, Thank you for the reply, I hope your move to KY goes smoothly, it's a lovely part of the world. Although disappearing, there are still some interesting bits of the old Tweed Valley line about, including the West Learmouth viaducts and the bits of Wark Station, and you can walk most of the route. Unfortunately the railway bridges at Wark and Cornhill, (which was Coldstream Station) have both been removed. There is a road-over bridge at Shidlaw which is worth a visit. There used to be a museum at Norham and the coaling building and station/signal box were preserved by the last owner. Since he died, sadly the site has gone over to a fully private residence at the moment.Dave S wrote: ↑Sat Dec 12, 2020 1:41 am I'm currently in the process of moving to Kirk Yetholm, I did initially look at a couple of properties in nearby Wark and noted the location of Sunilaws. I've been making a mental note of the closed and abandoned stations and lines to visit and walk and that is on the list.
