Edgware GN. What next.
Re: Edgware GN. Building another loco, a C12
GNR green (Shudder) I picked LNER black so it would fit in with all the other locos, I don't want it to be a shelf queen, the GC had a single in LNER black (I think) If I do go Green, I'd rather it be LNER green. Even if it is incorrect.
I had a very close look at it yesterday, and there is very little chance that I would be able to get a motor in it, there is so little room, I'll probably have to resort to a tender drive unit.
Black? The X4s were fully lined green, I think you'll find.
Just double checked, and you are correct, they were green........Hmmmmmmmmmm
Well, lets get the Bu**er running first.
Obviously manna is using rule No.1 loljwealleans wrote: ↑Fri May 11, 2018 5:33 am Black? The X4s were fully lined green, I think you'll find.
G'day Gents
Days pass and little by little things are taking shape, a chassis has been built for the resin coach, the Fox bogies were rediscovered and rebuilt, the underside of the chassis has been fitted with a couple gas tanks (she was always gas lit), the gas tanks were made from a 'tent' peg covered in plastic card, being heavy and very low down they add that weight just where it's needed, I have to leave it sitting on the sleepers, as it rolls very freely.
The Ivatt single, has been rubbed down, but the plastic is very hard, and dose'n't yield easily to a file or emery paper, so as a bit of a experiment, I'm going to give it a couple of coats of paint and then give it a rub down again, hoping the paint will fill in some of the lines in the body work..
I have painted the Single in wartime 'Grey', doesn't look to bad.
Re: Edgware GN. Building another loco,GNR A5 + others.
If you don't like the A5 in grey, how about black...................or green.
This last weekend was a public holiday, and our Model railway show, I met up with Woodcock 29, as he had some goodies for me, money changed hands, and I came away with a Gresley artic twin, an all third (suburban) and a Deal, full brake, a good half dozen kit built wagons were also included in the deal. The coaches are all kit built and not built very well, but they give you somewhere to start, roofs were removed (or fell off), bogies wouldn't turn, wheels were jammed, so a couple of days of intense modeling has given 3 new suburban coaches, I still have a few more bits to do.
The deal full brake, has been repainted into BR crimson, as it's a bit late for the LNER, and new wheels fitted, as it had been running with spoked wheels.
The goods vehicles have had couplings fitted to a couple of wagons, and a bit of a tidy up on a few.
A few more pics.
Also a 1st/third kit was included.
Work has been continuing on the A5, lots of rubbing down.
A few more pics.
Hi Manna
Glad you could make use of what you got on Sat. I think we'll have difficulty in getting rid of a lot of the other wagons and coaches, although another BRMA member came and got some wagons yesterday and the other Mailcoach Full Brake. The guy that built them had a layout but it was modular and he never had the space to assemble it so I don't think much if any of the stock had been run!
Happy modelling
Happy modelling
Andrew, I did wonder if they'd been run much, as wheels had brake shoes that were touching the wheels, also on the all third, the under-frame bracing was touching the bogies and wouldn't turn, so I had to cut them down to allow them to rotate, all good fun though.
Manna
I even purchased three of the coaches myself - not that I have time to upgrade them in the near future as the list of projects I have to undertake is enormous. I got a BT + Lav Comp twin and a 5 compt BT none of which I had. I also grabbed a couple of Parkside Fruit vans which weren't too bad.
Andrew, sounds like you got a bargain to, always come in handy.
Wow Manna, you've been busy! That's an impressive haul you got the other day. I really like the A5 but my favourite is the GNR resin coach body and under frame - just lovely!
Sorry for the tardy reply, but I have been flat out like a lizard drinking, The first/third has been built, but the truss frame and the battery box were missing, so I had to make those, the A5 has been rubbed down and has been painted again.
The luggage all third, after many weeks of research, (well 20 mins) has turned out to be a NER, built ECJS vehicle, not a GNR coach, which has not put a dampener on my enthusiasm for the vehicle, a truss frame (?) has been made and fitted, plus a multitude of roof detail fitted, only the ventilators were bought, the gas lamp tops and some domed ventilators over the corridor were made out of plastic rod.
Three parcels arrived last week from my son, a large smile is etched on my dial at the moment, a couple of 'Schools motorized tenders were in the haul, a Lima J50, more on that later, a complete Hornby N2 chassis, which is for a Hornby N2 body I had lying about, a tender for the LMS, Stanier 2-6-0, a B1 tender, and a tender off of a kitmaster Stirling Single (borrowed for the A5, for the moment), some wagons, and sundry, chimneys, domes handrail knobs, all the bits you need for modeling.
A few more.
A few more.
