Edgware GN. Building another loco,GNR A5 + others.
52D
Re: Edgware GN,
Post by 52D » Wed Jul 12, 2017 8:31 pm
Dave wrote:
Wed Jul 12, 2017 9:19 am
Blimey Manna what a collection of locos you are building up, very nice.
Is it not time you tried some proper engines from Darlington :) .
LIKE
Re: Edgware GN,
Post by manna » Thu Jul 13, 2017 6:54 am
Thank you Dave, I have far to many for the layout, but.......
As for NE loco's, there's not that many NE types that reached the 'Cross' Ravens A2 ! a very rare B16, what else :!: :!: I've done the G5, I know that J26's reached Peterborough and some were based in Norwich, now I'm stumped, I know a Q6 is a maybe under rule 1.
I've got a D49 and they were as rare as hens teeth, Over to you............
manna :?
Re: Edgware GN,
Post by jwealleans » Thu Jul 13, 2017 8:22 am
Atlantics got there on footexes and the like - there are some in Top Shed.
JASd17
NER C7 4-4-2
Re: Edgware GN,
Post by JASd17 » Thu Jul 13, 2017 10:03 am
Jonathan is right, NE Atlantics certainly turned up at KX.
In the Frank Giles note books for the southern end of the ECML he notes only A2s and C7s in the 1933-5 era.
Q6s are therefore definitely 'Rule One'.
O4s occasionally turned up amongst the usual diet of New England O1 and O2 2-8-0s.
4812
GNR J52 0-6-0T
Re: Edgware GN,
Post by 4812 » Thu Jul 13, 2017 11:38 am
Some (actually many) years ago a Peterborough driver told me of firing an ex-NE Hull 4-4-0 on a Wembley Exhibition excursion. He remembered it because the pick-up gear, presumably little-used at Hull, was immovable and they had to stop for water, but they did run through.
Re: Edgware GN,
Post by manna » Fri Jul 14, 2017 2:17 am
Thanks for the replies, well it looks like an Atlantic.............but looking through the NE Atlantic's, I came across the C9, now that looks interesting, I doubt if that ever got south of Peterborough, but what the heck, it might take a while, drawings etc (yes I do use them) and to acquire all the bits, I might have to call out for a bit of help, we shall see.
PS I have the relevant Green Bible.
Atso
Re: Edgware GN,
Post by Atso » Fri Jul 14, 2017 11:11 am
Looking good manna. I'm also interested in which NE locomotives made it down to the southern end of the LNER. I've got a Raven A2 in the design phase to fit on a modified Farish A1 chassis and would very much like a B16. The C7 sounds like another great locomotive to have but I think I'll sort out the chassis for a 'standard' C1 first!
Looking at your latest project, it looks like a C2 to me. One thing though, could you find a chassis with a closer coupled wheelbase? Personally, I think the 6'10 coupled wheelbase was very distinctive. My version of 3279 (hint hint Mr King!) uses a converted Jubilee chassis which at 7'3 is still almost a 1mm too long (six inches) but is hidden by some distortion of the locomotive body. The BR 5MT 4-6-0 sees to have used a 7' front coupled wheelbase (as I think did the Southern Arthurs and Nelsons) which would be very close in 4mm scale - I assume you're not going to consider hacking one of the lovely Bachmann C1s!
Atso-Cad Models
www.atso-cadmodels.co.uk
Re: Edgware GN,
Post by manna » Sat Jul 15, 2017 8:09 am
It just so happens I have a Hornby King Arthur chassis, so I had another look at it, it fit's the criteria, but the motor's had to be removed, as it's rear wheel drive and the motor's to fat, so a tender drive is still required, but I will now be using the KA chassis.
Re: Edgware GN,
Post by manna » Sun Jul 16, 2017 4:17 am
After a bit of work, an Atlantic has been made out of a King Arthur. Still rather rough, but something to build on.
I am building 3271, the only inside cylindered C2, I still might finish the older version.
Atso
Re: Edgware GN,
Post by Atso » Sun Jul 16, 2017 11:19 am
The KA chassis looks like a much better option IMHO, if I may (without pushing my luck too much further) suggest that you might consider shortening the distance between the bogie and the leading driving wheel? They really were bunched up together on the prototype; although not necessarily conducive for getting around model railway curves!
Atso-Cad Models
Re: Edgware GN,
Post by manna » Sun Jul 16, 2017 8:15 pm
G'Day Gents.
Hi ATSO, 3271, had a different length in her wheelbase, the distance between the front bogie and leading driver was a foot more than the others, the engine was, 13 inches longer and the boiler was 15 inches longer, so quite a different loco to the others.
When 'Woodcock 29' tried to run his C2 on my layout, there was one tight curve it wouldn't go round, that curve has now been eased, but I picked 3271 for that very reason, longer wheelbase.
Atso
Re: Edgware GN,
Post by Atso » Mon Jul 17, 2017 8:38 am
Hi Manna,
Interesting about the different wheelbase, I'll be studying harder in future! :D
Atso-Cad Models
Re: Edgware GN,
Post by manna » Sat Jul 22, 2017 11:19 pm
G'day Gents
The body for the (next) C2 is taking shape, a bit more needs to be taken off the chassis, to allow for the boiler to be fully round, just behind the smokebox.
Re: Edgware GN,
Post by Atlantic 3279 » Sun Jul 23, 2017 10:44 am
Already the unmistakeable inside-cylinder C2....
Re: Edgware GN,
Post by manna » Wed Jul 26, 2017 3:58 am
G'day Gents
The C2 is moving along at a fair pace, cab's almost finished, smokebox and smokebox door are now in place, and dome fitted, next is the splashers.
Thank you Atlantic 3279, doesn't take much to make a recognizable loco.
Now a plea for help, I'm looking for a couple of Lima J50 body's, I only need the chimney's and domes, so if the buffers or cabs damaged, no matter. Thanks
