Station Platforms
Kyle1987
Station Platforms
Post by Kyle1987 » Sat Jul 08, 2006 10:55 am
Hey all
I was just wondering if anyone knew what type of brick/stone the LNER used for their station platforms. I'm currently building a railway and was just wondering if anyone could help me :)
Kyle
Bullhead
Post by Bullhead » Sat Jul 08, 2006 1:33 pm
I expect that brick, stone, cast concrete sections, and even timber were used - this would presumably depend on what was available locally, at what cost, and what the particular application was (new build? extension of an existing platform? patching damage?).
richard
Post by richard » Sat Jul 08, 2006 2:21 pm
Yes, most would have been inherited from the constituent railways. The stations in the NER area will look different from the GER, which will look different from the GNSR, etc.
Suddaby
Post by Suddaby » Sat Jul 08, 2006 2:28 pm
As Richard says, most of the LNER stations were built by the pre-grouping companies - or even earlier companies. I am not sure that even they would have a "house style" as you might say, using local architects,materials and builders.
The answer really is to decide where your model is situated and then get photos of stations in the area. Usually stations built on one line exhibit some sense of uniformity, but not always - for example stations on the Pateley Bridge branch are all very similar, but look at the stations on the Harrogate - Ripon line that it branches off and they are to a totally different style.
Kevin
Colombo
Post by Colombo » Sat Jul 08, 2006 8:57 pm
As a matter of interest, York Station and Hotel are yellow Scarborough Brick, chosen to tone with the Dolomitic Limestone of the adjacent Bar Walls. However, I recall that all the surrounding railway buildings are red brick.
If you are using Slater's plastikard, which is probably the best method, you can decide which brick bond to use as most common types of bond are available; for brick bonds see:
http://www.diydata.com/planning/brick_b ... _bonds.htm
You should compare these bonds with your photograph of the building and choose your plastikard accordingly.
The old railway companies were building solid walls and so did not use our modern stretcher bond which we now have to use for our cavity walls.
Colombo
Bullhead
Post by Bullhead » Sat Jul 08, 2006 10:11 pm
Peco produce nice modular platform edges and ramps (as well as not very convincing surface sections), which you can face with Slaters Plastikard.
Kyle1987
Platforms
Post by Kyle1987 » Sun Jul 09, 2006 9:31 am
i'm making my platforms out of wood, then planning to stick/glue brick/stone print (probably from the net) to them so i can have the correct angles.
as for a location, i haven't really decided where it is (it's a fictional area- Kyleton and Notelyk)
i'm really not all that fussed on the style (i can always change it in the future if i want to) as it really is just for some fun. i guess i might just go with what looks good, lol
