Fish vans
Re: Fish vans
Doesnt work for me , thats the link !!
Re: Fish vans
Nor do I partake of the book of the face, nor ye twitter. Don't want too much of my life and details to be known to one and all...... don't have time to post it all up anyway!
Re: Fish vans
OK guys will post hard copy tomorrow, thought it might add variety to fish trains, you seem to be turning up odd vehicles for this traffic everytime i log in.
- Dave
Re: Fish vans
Thanks 52D
I will look forward to the pic as I too do not do facebook, now where is my mobile.....lost it again
Re: Fish vans
Evergreen strip makes up the solebars. I used a triple laminate to make up the thickness. This way, I had a thin enough layer to gently punch out the bolt marks from behind and then stick this to the other pieces. Somewhat parsimonious, you might think, but it was alot quicker than applying proprietary rivets/bolts.Atlantic 3279 wrote: And what did you do to produce the underframe?
Headstocks integral with the body ends from ABS.
Re: Fish vans
Hello all
I've just found this thread and it's very useful as I'm building a fish train to fit behind a Millholme B5 that I built a while ago.
I have ordered a Brassmasters bogie van (I dreamed of owning a complete train, back around 1980, but discovered that they didn't run as complete trains).
I was captivated by the diag 37 LWB van in Tatlow's 4A, and decided to attempt one. The Parkside/Peco GWR Mink D seems suitable with one section of panelling removed and Evergreen strip outside framing added. The ends need to be rubbed down and new struts added.
My modelling is slow at the moment as I'm helping the GF move into the house that she's inherited.
If I am successful, I will post the result.
Re: Fish vans
Earlswood
When you build the kit I suggest you read Steve Banks article on his website. Unless Brassmasters have modified the kit since they acquired it from R&E you'll find the planking in the doors doesn't line up with the rest of the sides and needs to be modified during construction.
- Chas Levin
- NBR D34 4-4-0 'Glen'
Re: Fish vans
Andrew's right - here's the one I built a few years ago, before reading about the mismatch and - to be fair to myself - before I'd have had the ability and confidence to attempt modifying it:
Just joking: my real point is that it's a nice kit, went together smoothly, good instructions and it runs beautifully! The one tricky bit was getting the large 'N' and 'E' on flat over the inter-slat gaps and then slitting along the slat edges with a razor blade to remove the cut-out sections, which calls for a new, sharp razor, a steady hand, good lighting and no drinkies
The photo's a little poor too I'm afraid, but actually, what it does show is that if you don't fancy modifying the kit, it can still look perfectly acceptable from normal viewing distance - if you're still sceptical, you could print the photo out at 4mm scale, stick it on a suitably sized block of wood and pop it on your layout! Just joking: my real point is that it's a nice kit, went together smoothly, good instructions and it runs beautifully! The one tricky bit was getting the large 'N' and 'E' on flat over the inter-slat gaps and then slitting along the slat edges with a razor blade to remove the cut-out sections, which calls for a new, sharp razor, a steady hand, good lighting and no drinkies
Chas
Re: Fish vans
Good morning all from sunny Surrey,
Thanks for the replies. It is good to know the problems before I start soldering.
Earlswood Nob
Earlswood Nob
Re: Fish vans
I'm progressing slowly with the construction of my first etched kit.
The instructions state that split spoke wheels were fitted to the original bogie fish vans, but studying Tatlow, it looks like solid spokes. |Which is right?
Re: Fish vans
i think you can get way with either, Malcolm, and the more so the further into their lifespan you model. Wheelsets were routinely swapped when the wagons were maintained.
Re: Fish vans
I cannot say definitively that this applies to the fish van but I have seen examples where one wheel set on a bogie is spoked and the other is solid. I guess this arises from maintenance needs with a set heavily worn and the other still usable.
Never wazza Fish vans
G'day all from sunny Surrey
While reading Tatlow's LNER wagons; I noticed two diagram numbers reserved for fish vans which were never built.
Does anyone have any Idea what the 6w and bogie vans would have looked like?
Guessing the 6w would be similar to the LMS post war vans, then it might be possible to construct something from two Parkside d134s.
Would the bogie van be based on the GCR bogie fish, or would it be similar to a short bogie brake?
