Fine scale wheels
Fine scale wheels
ok so i decided to repaint one of my old hornby A1's last year, the intention was to return 4472 to traffic as 4476, with all the painting and transfers done i want to replace the wheels and valve gear.
does anyone know where i can get a replacement wheel set that includes the valve gear and connecting rods. I thought Romfords but they only include the wheels and axles, but i can't find etched valve gear. The sets also include the tender wheels which i don't want as it is tender drive, too many problems changing them over. I also made the mistake of using it half finished and i kind of forgot about it. One year later... (i'm sure we've all done it)
Many thanks for any help.
Simon
Simon
Hi Simon,
Comet Models sell an etched fret of valve gear and coupling rods for an A1/A3. (ref LM30 in the LNER locos section)
http://www.cometmodels.co.uk/index2.html
Also Alan Gibson does the valve gear (ref 4M55/15 near bottom of page) but not the coupling rods.
http://www.scalefour.org/ag/ag4det/rods ... lve%20gear
However Martin Finney sells the coupling rods from his etched A1/A3 kit separately (ref E26 near the bottom of this page).
http://website.lineone.net/~cbwesson/4mm.htm
As far as the wheels go you can buy the Romford/Markits wheels separately and these are probably the best to go for if modelling in 00/EM. Alan Gibson is another option for a similar price. Finally if you want the Rolls Royce of wheels and a long wait then there is Ultrascale but an £15 per axle for a set of drivers even I have to swallow hard when ordering them.
Cheers,
Morgan
Cheers,
Morgan
Thats great, thanks. i'll have a look at the comet stuff, i think i'm going in the Romford direction i've used them before on a kit. I did bulk at the price of the ultra scale wheels, £57 for the A1 wheel set.
Does the Hornby old A1 have scale spaced drivers or am i going to have to fiddle?
Many thanks again
Simon
Many thanks again
Simon
I have an A1 I'm going to do as Flying Fox. My advice would be to go the whole hog with the Comet chassis pack, a beefy motor, plenty of lead and forget the tender drive. You'll get a loco which will pull a house.
I did a B17 with their pack last year and was very happy with it. If Golden Arrow still do their streamlined B17 body I may do one of those one day. I don't think you can do better than driving the loco.
The A1 I had was a great runner - I stopped bothering to try it at 18 bogies on my dad's layout - but suddenly stopped pulling at all and I discovered has a crack in the chassis of the tender drive. Not dropped (AFAIK) or mishandled - just fatigue, I suppose. That and the very variable (and noisy) characteristics of those drives makes me abandon them as soon as I can. If you're going to go to the effort of assembling the valve gear, for a little extra effort you can transform your loco.
Fine scale Wheels
Romford/Markits do 3mm axles as do Gibson
Thank you to all the people who replied.
I'm still a little uneasy about the loco drive conversion but maybe one day. I will have to see, the new hornby A1/3 does look very impressive and i imagine no matter what one does you will never fully manage that. Although i guess a new chassis and front bogie would go a long way. I have been contemplating repainting my other A1 just to update to a more accurate livery colour and the correct black buffers.
I must get on and order Royal Lancer's nameplates. And replace that buffer which just fell off. lol
Thanks again
Simon
Thanks again
Simon
- richard
I've seen it for sale in model shops here in the US. No doubt at a highly inflated price - a slab of mould-able lead in a blister pack!
Even as a kid, lead was getting harder to find. For model plane weights, we used the sheath from an old lead cable! Old water pipe is another option (you'll need to remove the lime build up). An old lead battery might be an option if you had a safe way of handling the acid (not down the sink or dumped in the garden!). You would also need to thoroughly clean the plates before moulding them.
Simon,
Have a look at this link. "Liquid Lead" is quite good stuff or just roofing lead from the DIY shop should be readily available.
cheers,
Morgan
http://www.electricnose.co.uk/tips/weights.html
cheers,
Morgan
