N Gauge G5 0-4-4T Build
Decided to start the ex-Highfield Models (now BH Enterprises) North Eastern Railway G5 body kit today. VERY basic and simple, basically the body sides, front/back, cab front and back, roof, boiler, tank tops and a few small ancillary items - four buffers, chimney, dome, safety valve cover.
Chassis wise i'm going to use that from the Del Prado 1/160 Highland Railway 'Duke' class 4-4-0 with the gap between the wheels increased to fit N and the rear bogie wheel spacing set further apart to more closely resemble the G5.
To be finished in NER green - found today that Humbrol 116 'US Dark Green' makes a nice match as NER passenger green
Alongside an N gauge 1911 Daimler lorry
Re: N Gauge G5 0-4-4T Build
A good looking loco, the front splasher/sandbox is very wide, is that to help with adhesion, ie the amount of sand.
Actually looking at the images again it doesn't look quite as bad! I think the wide splashers are a kit inaccuracy, as mentioned it's very basic, the Stockton & Darlington 1001 'Long Boiler' class is worse, and i'm yet to figure out what half the parts are actually for - although chassis wise, this French loco also made by Del Prado could be fairly close;
http://www.diecastlovers.com/collectabl ... ais-31891/
Would a Dapol M7 chassis work? I've got one that struggles to shift itself!
I was told it should do with metal carved away - I only want it as static as motive power will be from the J27, as well as J25 and D20 when I can afford them - may motorise an NER BO-BO freight locomotive too, some of the Kato chassis look suitable
I have recently joined the LNER forum. I have been modelling in N Gauge since around 1967 and my current layout 'Ferryhill' (not associated with any real 'Ferryhill' locations) is a double track continuous run layout set in the north-east of England during the steam/green diesel transition era.
I have always been interested in the early history of British N gauge and I have been researching the models made by Peter Middleton and his company Highfield Models. My first N gauge models were the Minitrix J63 white-metal kit and the South Leicester P.O. wagon from Highfield Models.
Although I do have the BHE G5 kit, I decided that an easier route to a G5 was to modify a Dapol M7, which is what I did.
Unfortunately, the photos referenced in the original post of this thread do not show up on my computer for some reason (well, its been a while since the original post!). I would love to see the photos of the BHE LNER G5 loco made by Rlangham if they could be reposted.
I would also love to see any other photos of N gauge models associated with Highfield Models made by modellers that may be members of this forum (I realize that this may be a long shot).
Thank you.
Ian
Thank you.
Ian
- LNER Thompson L1 2-6-4T
I'm waiting for Dapol to bring out their revised M7 loco later this year. The chassis looks to be light years away from the original, promising significantly-improved haulage, better detail, better motor and pick-ups. NEM coupler pockets and DCC 'friendly'. Mind you, it would have been almost impossible NOT to improve the previous chassis!
I bought a 3D-printed Recreation21 G5 body from Shapeways some months ago which is dimensionally accurate. Whether that will be able to fit over the new M7 chassis goodness only knows, but I live in hope.
I also bought a G5 body (Shapeways print) from recreation21. As you say, it is probably dimensionally accurate.
Unfortunately, I found the 3D print to be too narrow at the front splashers and it would not fit over the original (Mk 1) Dapol M7 chassis/wheels. I would be doubtful if it fill fit over the new, improved Dapol M7 chassis, but I live in hope!
Ian
Ian
Yes the G5 on Shapeways is, ironically, too accurate! The body is modelled exactly to scale, so the wider-than-scale N Gauge wheels won't fit. Perhaps the splashers could be widened/removed and remade without compromising the appearance too much?
