Rustys workbench - builds and paints
Rustynuts
Re: Rustys workbench - builds and paints
Post by Rustynuts » Sun Jan 15, 2017 8:12 pm
As an aside, here are some photos of the 7mm 1928 tender for my build of "Knight of the Thistle" using the Hachette Flying Scotsman as a basis:
60117 Bois Roussel
Post by 60117 Bois Roussel » Sun Jan 15, 2017 8:23 pm
Ah, Paul, sheer poetry!!
But as regards the Mousa Models etched brass goods wagon, personally I think it's the wrong material for the job, and the etched line surrounding where the strapping should go is a no-no: it reduces the area to be bonded and when it's larger than the item to be soldered over it, well, you can see the result for yourself. All it needs is a short vertical dash which you can extend with a pencil to aid the location. Why make life more complicated, especially if in practice it's a poorer solution?
Last edited by 60117 Bois Roussel on Mon Jan 16, 2017 3:18 am, edited 1 time in total.
Rustynuts
Post by Rustynuts » Sun Jan 15, 2017 9:20 pm
End of day 2, corner plates and solebar overlays on:
Rustynuts
Post by Rustynuts » Mon Feb 06, 2017 3:41 pm
Current sate of play after the 3rd evening, most of the strapping on and getting ready to sort out the brake gear etc:
Rustynuts
Post by Rustynuts » Sat Feb 11, 2017 1:35 pm
4th evening of work and another update, strapping all finished buffer stocks and axleboxes/springs added:
Rustynuts
Post by Rustynuts » Wed Feb 15, 2017 4:54 pm
Most of the Brake gear now on:
Rustynuts
Post by Rustynuts » Thu Mar 09, 2017 4:31 pm
Last two shots before painting:
Rustynuts
Post by Rustynuts » Thu Mar 23, 2017 10:06 am
Now in basic paint and a start made on lettering:
Rustynuts
Post by Rustynuts » Fri Apr 14, 2017 1:58 pm
Here we go, all finished:
With a LB&SCR horsebox I have re-gauged and weathered:
Rustynuts
Post by Rustynuts » Sun Jul 16, 2017 10:04 am
Been a while but here is a NER Dia G2A 12t Covered Van by 51L. It was an eBay cheap buy then rebuilt and painted.
Rustynuts
Post by Rustynuts » Mon Dec 18, 2017 12:37 pm
Finally getting on with my 4mm A3 'Felstead ' here is the first pics of the chassis build main parts cleaned up ready to go:
Post by Dave » Mon Dec 18, 2017 3:15 pm
Excellent work, the tender is a joy.
Rustynuts
Post by Rustynuts » Mon Dec 18, 2017 7:29 pm
Frames soldered together and bearings all lined up:
Image[/url]
Rustynuts
Post by Rustynuts » Fri Dec 22, 2017 12:06 am
Latest Update; Chassis now has new RP25 Markits wheels and the main connecting rods fitted, after a brief flirtation with Markits new Stainless steel crank pins I have reverted back to Markits Super Deluxe brass ones which have worked a treat.
Rustynuts
Post by Rustynuts » Sun Dec 24, 2017 10:44 am
Cylinders and Brake gear now fitted, bit fiddly but got there in the end:
