Rustys workbench - builds and paints
Mersey508138
Re: Rustys workbench - builds and paints
Post by Mersey508138 » Sun Dec 24, 2017 5:13 pm
What class of loco is the tender going to be part of.
Looks good
Rustynuts
NER J27 0-6-0
Post by Rustynuts » Sun Dec 24, 2017 5:56 pm
Hi There,
It will be LNER 2564 so an A1 "Knight of the Thistle"
Rustynuts
NER J27 0-6-0
Post by Rustynuts » Tue Dec 26, 2017 1:47 pm
Started on the valve gear, using a mixture of DJH and some spare SEF parts to make the valve spindle move:
Post by Atlantic 3279 » Tue Dec 26, 2017 2:10 pm
Also to be built in forward gear?
Rustynuts
NER J27 0-6-0
Post by Rustynuts » Tue Dec 26, 2017 6:17 pm
Just getting everything free at the moment, but may set it in forward we shall see as it entails more mods to the etches and the DJH ones aren't the best.
Rustynuts
NER J27 0-6-0
Post by Rustynuts » Sat Dec 30, 2017 7:11 pm
Not the best photos but i have swapped out all of the DJH valve gear with Comet ones, I think they are much better and are very free running:
In the next picture you can see the expansion links, I have built one already and as you can see it has 3 components to it:
Post by Atlantic 3279 » Sun Dec 31, 2017 10:58 am
Should you come to grief with the multi-layer expansion links I have some small etches of spare links that you could use to salvage the situation. They go together slightly differently, but working out a suitable method is not beyond human powers of imagination.
Rustynuts
NER J27 0-6-0
Post by Rustynuts » Sun Dec 31, 2017 11:21 am
Many thanks for that but it has all has gone together OK.
Just been painting this Mess van, originally built it without the beading but i finally decided to strip it down and add it:
Have a great New Year.
Rustynuts
NER J27 0-6-0
Post by Rustynuts » Mon Jan 01, 2018 1:22 pm
Happy New Year to all:
Decided to go down the Comet route for the front Bogie as well:
Here it is partially built, just the pivot to sort now:
Rustynuts
NER J27 0-6-0
Post by Rustynuts » Sat Jan 06, 2018 11:39 am
Getting there with the Chassis:
Another eBay find and rebuild, almost done:
Rustynuts
NER J27 0-6-0
Post by Rustynuts » Tue Jan 09, 2018 12:41 pm
Another eBay purchase, stripped and rebuilt with MJT Queen posts, ABS bogies and Lanarkshire Models & Supplies buffers:
Rustynuts
NER J27 0-6-0
Post by Rustynuts » Sun Feb 11, 2018 2:29 pm
Getting on well with the cab:
Rustynuts
NER J27 0-6-0
Post by Rustynuts » Sun Feb 11, 2018 2:30 pm
Cab roof on and sitting on the footplate, starting to look like a loco now:
nzpaul
Post by nzpaul » Sun Feb 11, 2018 9:15 pm
Nice job,the expansion link really looks like it's worth the effort. Just curious to know how you've dealt with fixing the eccentric crank to the threaded crank pin. Is there a nut securing it or have you threaded the part onto the crank pin?
Rustynuts
NER J27 0-6-0
Post by Rustynuts » Mon Feb 12, 2018 11:29 am
Actually it is soldered, I did look at using Markits latest machined return crank but it needs a 2.4mm hole in the connecting rods and there wasn't enough meat on the comet valve gear.
Now got the boiler on:
