Rustys workbench - builds and paints
S.A.C. Martin
Re: Rustys workbench - builds and paints
Post by S.A.C. Martin » Tue Dec 18, 2018 5:10 pm
Some lovely work there Rusty. The Q1 piques my interest in particular. I'd always heard the Millholme one didn't make a particularly convincing model but yours looks excellent, refreshed. Been considering getting a cheap GWR ROD off Hattons to cut and shut into a Q1 or Q4 (or both!)
Rustynuts
NER J27 0-6-0
Post by Rustynuts » Tue Dec 18, 2018 5:18 pm
Thanks will look a lot better with brake gear etc, I do have a second Q1 which I picked up together with yet another NuCast Q6.
Rustynuts
NER J27 0-6-0
Post by Rustynuts » Sun Jan 06, 2019 6:14 pm
Just started stripping down 3 partially built kits I bought at auction, luckily they have been built well but with 5 min epoxy so some soaking in thinners and they are coming apart well:
NB Models 0-6-2 N15 Kit (unbuilt)
Nu-Cast SP122 2-4-2 F4 Class,
Nu-Cast NC103 0-4-4 G5 Class,
DJH K26 4-4-4 H1 Class
for some reason I have accumulated 4 Nu-Cast Q6 locos so will strip those and rebuild them with finer scale wheels etc, will probably get 3 good ones from the 4
drmditch
NER C7 4-4-2
Post by drmditch » Sun Jan 06, 2019 11:28 pm
I am not sure that the Nu-Cast Q6 builds into a reasonable representation of the prototype. The boiler being both too narrow and too short.
There is a discussion on Page 7 of my 'Make do and Mend' thread (sorry, can't work out how to insert a link using this tablet. Will try to correct tomorrow using a proper keyboard.)
Their J21 however does seem to be quite accurate.
I have two Q6s, one built from a Dave Alexander kit, which is just about my best locomotive, and a slightly modified Hornby one, which also looks good.
The Nu-Cast Q6 is much more like a Q5.
My DJH H1 eventually got re-built (prototypically) as an A8.
Rustynuts
NER J27 0-6-0
Post by Rustynuts » Fri Aug 30, 2019 11:36 am
I did eventually finish painting the D&S GN 8T outside frame van:
Post by Atlantic 3279 » Fri Aug 30, 2019 1:39 pm
Nice to have an update.
Post by Dave » Fri Aug 30, 2019 4:44 pm
Seconded Atlantic
Rustynuts
NER J27 0-6-0
Post by Rustynuts » Mon Sep 02, 2019 6:24 pm
Been busy painting 7mm locos, wagons and working on the house!!, sorry some not LNER:
GER Continental Cargo Wagon:
LNWR Cooke 0-8-2T:
Black 5:
Pebbles
Post by Pebbles » Tue Jan 21, 2020 10:01 am
Some years ago maybe, but did you encounter a problem with the coupling rods being only 32.5mm rather than 33mm?
Pebbles
Post by Pebbles » Tue Jan 21, 2020 4:18 pm
Sorry I realise that I have not made myself clear, I'm referring to the Craftsman C12 coupling rods.
Rustynuts
NER J27 0-6-0
Post by Rustynuts » Sat Jan 25, 2020 11:43 am
No they seem to be OK, I'm using Markits wheels and their deluxe crank-pins but with some reaming out the chassis is nice and smooth.
Rustynuts
NER J27 0-6-0
Post by Rustynuts » Sat Jan 25, 2020 12:19 pm
More work done on the Q1, looks a bitter better now than when i started:
Pebbles
Post by Pebbles » Sat Jan 25, 2020 3:24 pm
Many thanks for your reply.
