Page 4 of 4
Re: Butler Henderson Premiere
Posted: Sun Nov 11, 2012 11:00 am
by K160
Just seen the images on the previous pages. What a great model!
Posted: Mon Nov 12, 2012 6:30 pm
by Coboman
Blackout60800 wrote:The 04 is geared nice and low - my lowest infact.
Kestrel wrote:With a GCR version, a green BR one and three black BR ones available, I rang Bachmann to ask about a D11 in LNER livery. All they would say was "Wait until the 2013 catalogue comes out in March and see if one's in there."
Thanks Bachmann.
It's more than you get out of Hornby.
Whats that? the dial tone?
Posted: Tue Nov 13, 2012 3:22 pm
by 2512silverfox
Prince Albert is being touted by Rails with a photo. Question for the BR cognoscenti: I thought the D11s carried full MT lining from Nationalisation? The model illustrated is in plain black livery with early emblem.
Posted: Tue Nov 13, 2012 5:58 pm
by Horsetan
Some D11s did carry plain black, and "Prince Albert" was one such. I think there's a photo of it in the Johnson book.
Posted: Sun Dec 23, 2012 2:05 pm
by Atlantic 3279
Posted: Wed Jan 02, 2013 11:47 am
by Atlantic 3279
Some notes on the trials and tribulations of fitting other details here:
viewtopic.php?f=3&t=2443&start=2415
and
viewtopic.php?f=3&t=2443&start=2430
Posted: Mon Jan 07, 2013 8:33 pm
by 45609
Good Evening Chaps,
Yesterday I received a Birthday gift, a Prince Albert. Stop sniggering King you know I mean the Bachmann D11/1! Anyway I spent Sunday evening having a good look over the model and have a few observations to report. I'm sure some of you will argue that I'm being very pernickety but there may be a plan behind this excessive nit picking. So bear with me.
Here goes, starting from the front of the loco, recognising that these comments refer to the D11/1s as the appeared under BR ownership.
1. Buffer beam has no rivet detail. Most D11/1s ended up with snap head rivetted buffer beams
2. Buffers are a good representation of the GCR parallel housing, oval headed type. 62665 had group standard buffers
3. There is a lot of snap head rivetting on the lower front portion of the running plate which does not seem typical. There is probably some rivetting there but it must be near flush as it hardly shows up in photographs.
4. The pot lubricators almost in line with the smokebox front on the front of the frames are incorrect for the BR period and appears to be only a GCR period feature.
5. The 'U' shaped bolt head pattern on the front frames is only correct for 62660 in BR days. By this time the rest of the class had been fitted with new cylinders and long travel valves. The rivet pattern was two closely spaced horizontal rows of 6 and 5 bolt heads. The definition of the bolt heads is also a bit light.
6. Smokebox snap head rivet pattern looks to be ok. I've only noticed the odd variation.
7. The chimney flare seems to be a bit plump and definitely of the original GCR pattern. Not the later pseudo-GCR pattern designed by Gorton to enable the snifting valve to fit on the top of the smokebox directly behind the chimney. The fact that the snifting valve is present and seems to fit is a little perplexing. I'm not yet fully convinced of what is amiss so a few measurements need to be taken.
8. Wakefield lubricator on the right hand running plate is wrong. It was only a feature of the D11/2
9. Splasher beading is printed (fair enough) but why in silver and not gold. The beading and name plate was brass.
10. Curved reach rod is correct for all except Bulter Henderson but is wrong for front frame bolt heads (point 5).
11. A variety of missing pipework on the boiler sides due to the incorrect (D11/2) configuration lubricator
So that's it in the fidelity stakes. So far. I have yet to look at the tender. There are also a few irritating quality issues with mine straight out the box. A broken reach rod support, safety valve and whistle all leaning backwards, sand and injector pipes not fitted properly. It doesn't bother me too much as most of this will be coming off for some upgrade work.
So here is the question. Would there be interest in a few parts to deal with a number of very correctable errors? My list is currently...
Rivetted buffer beam
Alternative front frames (overlay or new complete assembly to be decided)
Splasher beading (possible with integral nameplates). See a separate poll that I have started
New reach rod and lever (2 types)
I'm also considering chimney and alternative domes (tall round and tall angular)
Cheers....Morgan
Posted: Tue Jan 08, 2013 10:21 pm
by 60800
Well, b####r....
506 started to run jerkily, so I took of her off the track, cleaned, oiled the loco etc. No joy. Took the body off and found I'd left one of the two capacitors on. Snipped it off and the loco decided to get worse. What could be going wrong? Could the decoder be damaged from running with a capacitor?
EDIT: Not the best place to post this, but I'm in disarray
Posted: Tue Jan 08, 2013 10:59 pm
by Atlantic 3279
mlgilbert30 wrote:Stop sniggering King you know I mean the ......
What? Me? Never!
Thank goodness for the inside cylinder arrangement. Nobody will ever be able to see the condition of your big end.....
Posted: Tue Jan 08, 2013 11:16 pm
by Horsetan
mlgilbert30 wrote:....Would there be interest in a few parts to deal with a number of very correctable errors? My list is currently...
A CSB-friendly chassis would be a good start, particularly if I can put inside motion in it
Atlantic 3279 wrote:.....Thank goodness for the inside cylinder arrangement. Nobody will ever be able to see the condition of big end.....
They will on mine
Posted: Tue Jan 08, 2013 11:41 pm
by 45609
If I can be arsed Mr. Tan. I think I might just scratch build myself a chassis. Anyway Ivan I thought you had a Perseverance D11 kit to build? Mind you will find that turns out to be an exercise in scratch building anyway.
Tsk....and I placed my bet on you saying something about making sure it was well lubricated when banking.
Posted: Wed Jan 09, 2013 12:15 pm
by Horsetan
mlgilbert30 wrote:....If I can be arsed.....
I'll take that as a "no", then
Posted: Fri Jan 25, 2013 10:35 pm
by 45609
Evening all,
Well my suggestion to do a few detailing bits didn't seem to generate a great deal interest. Nevertheless my poll of favourite names came out with Jutland top followed by Butler-Henderson and Ypres on equal votes. Bearing this in mind I've now prepared the name plate and splasher beading models for these three. See the photos below. I'm going to push on with this anyway because I want to detail up my Director. If you're interested then please do PM me so I can get back to you when I'm ready to put an order into the etchers. No obligations just yet.
Cheers....Morgan
