Page 1 of 18
Much doodling at Earlswood
Posted: Sun May 05, 2013 6:09 pm
by earlswood nob
Afternoon all
I’ve been very busy of late as while doing some genealogical research for somebody else, I found references to my own ancestors, so now I’m busy chasing my own family.
The D7 is progressing slowly as I don’t have a drawing and all measurements are guesses. I make something and if it fits and looks right its OK, if not I have another go and make it again, and so on.
However, I’ve started yet another loco. This loco is going to a simple loco with a straight footplate, so should not be difficult to build.
I have started by soldering strips of brass to make the footplate outline. The footplate is 118mm long.
The boiler assembly should be ready to fit tomorrow, and you might get a better idea as to what it is then.
Earlswood Nob
Posted: Mon May 06, 2013 12:48 pm
by earlswood nob
Afternoon all
Had a good morning, even if I was feeling delicate, but Green Tea and a long walk straightened me up.
I finished the basic boiler, its 22mm tubing wrapped with two layers of 0.5mm plasticard, with an additional two layers for the smokebox.
The boiler is merely balanced on the footplate.
Now its out with the filler to blend in the valve chests to the smokebox. I wonder if anyone has any ideas as to which class it is, before I build the cab.
Earlswood Nob
Posted: Mon May 06, 2013 3:59 pm
by ten ten
Wasn't there a tiny mention in your recent thread ?
Posted: Mon May 06, 2013 4:52 pm
by Atlantic 3279
I shall remain silent (as I feel our previous private discussions provide me with too big a clue), save to point out that your quoted boiler dimensions rule out a Q4........
Posted: Mon May 06, 2013 5:58 pm
by auldreekie
J27? But the boiler's too fat (or is that a 3" allowance for cladding?).
auldreekie
Posted: Tue May 07, 2013 5:21 pm
by earlswood nob
Afternoon all
Not much has happened as I started running out of materials and had to visit the model shop in the great Wen for more. I also managed to find some small strip plasticard to produce the beading on the tender top etc.
I started the tender and made the side sheets, and glued triangular strip to the body to make the flare.
The tender chassis posed another problem as it’s not a size produced by Comet, so I had to build one from brass strip.
I should have a more productive time tomorrow morning and hope to make the loco chassis and cab.
It is not a J26/7, but does have a J26 type chimney.
Earlswood Nob
Posted: Wed May 08, 2013 4:55 pm
by earlswood nob
Afternoon all
I was able to get some work done this morning. I built the chassis for the loco. Usual method solder two brass strips together and drill the axle holes and shape the frames. Then split the strips and use Comet jigs to line up the chassis and solder spacers between the frames. I “borrowed” some wheels from another of my projects fit temporarily.
A bit of time was spent on the superstructure, as I had to make a new valve chest as the previous one was incorrectly glued to the bottom of the smokebox.
I also started building the cab and once the correct shape is obtained, the windows etc with be cut out.
I am now going to spend an hour trimming flanges on some old Romford drivers.
Earlswood Nob
Posted: Wed May 08, 2013 6:29 pm
by Pebbles
A Stirling Engine?
Posted: Wed May 08, 2013 6:44 pm
by mick b
Q1 / Q2 or H&BR Q10
Posted: Wed May 08, 2013 9:38 pm
by auldreekie
Reboilered Q10 (H and B R Class A) looks possible...
(Unless you're considering the "two-tubes and plate/infill" dodge to build a belpaire firebox on to the boiler tube.)
auldreekie
Posted: Wed May 08, 2013 10:19 pm
by ten ten
Second Auld Reekie's deduction.- a reboilered Springhead "Tiny". Should be quite an unusual and imposing beast.
Posted: Thu May 09, 2013 6:05 am
by earlswood nob
It is the rebuilt Q10 with the roundtopped/domed boiler.
I was bemoaning the fact that my Nucast Q6 is too short and wondering what I could do with it. I thought of a Q5/2 with the ex-Q10 boiler. On reading the Q10 passage in the Green Book, and found they were rebuilt with roundtopped boilers and when replaced by O4's on the H&B line, some finished their days at Mexborough. I wouldn't be surprised if they were used for banking on the Worsborough incline as many locos were pressed into service on that duty at the end of their lives. That is the general sort of area I model (with allowances for Gresley locos, now was a P1 ever used over Woodhead?).
I shall be busy today so the only objective is brake gear.
Thanks for the interest.
Earlswood Nob
Posted: Thu May 09, 2013 9:00 am
by auldreekie
That WILL be something to look forward to, not least because so unusual...
auldreekie
Posted: Thu May 09, 2013 9:50 am
by jwealleans
Have you found the previous builds on here?
Posted: Thu May 09, 2013 11:08 am
by earlswood nob
Hello JW
I have just looked through and found Rob's workbench and a Zenith kit Q10. I didn't even realise that a kit had been produced.
It was interesting to notice that you remarked that you have a Raven A2 to build. Have you built it yet? I too have one in the cupboard, which will get built sometime. I have so many kits to build, and I'm getting a taste for trying to scratchbuild the unusual.
I must get out and do some work, for there's no modelling today as I've cut a finger (on a foil sachet of seasoning, would you believe). What will happen when I shave??
Earlswood Nob
