Can anyone recommend a good book explaining shed numbers please - and does any one know what Reedsmouth's was. I have been told it was C1 9/52 but that does not seem like any other shed code I have seen previously?
Thanks again in advance
Reedsmouth Shed Number
Reedsmouth shed
At the grouping Berwick shed was responsible for Reedsmouth. When Berwick shed closed circa 1924 Tweedmouth assumed responsibility I will re post when i have checked dates and transfers. As the last contributor says Blaydon eventually took over.
Reedsmouth Shed
From North Eastern Locomotive Sheds by K.Hoole The ex NBR shed was transferred to the North Eastern area of the LNER on 1 August 1924 becoming a sub shed of Tweedmouth. Later Heaton was the parent shed then eventually Blaydon took control.
At some time Reedsmouth locos carried the identification R'MTH on the front buffer beam.
Unfortunately apart from the first date i have no other dates of changes.
The locomotives present at Reedsmouth shed on 1 August 1924 were class D51 4-4-0T 1402, class J33 0-6-0 9024 and 2 class J36 0-6-0 9754 & 9779.
