Loaded weight of a 16ton mineral wagon
cunningnLNER
GER J70 0-6-0T Tram
Post by cunningnLNER »
This will sound like a stupid question to those in the know - but I am confused as to the fully-laden weight of a '16 ton' steel bodied mineral wagon (BR era). I have seen it described as having a 16 ton capacity and also as a 16 ton load. But in many discussions there is an implication that it is 16 tons in total weight when fully loaded - with the wagon itself weighing around 7.5 tons - implying a 8.5 ton maximum coal/mineral load.
Any clarity would be gratefully received as there is quite a difference between pulling 30 16 ton wagons and pulling 30 24 ton wagons!
Neil
Re: Loaded weight of a 16ton mineral wagon
16T is the load capacity - if the tare weight (the wagon itself) is 7 tons then the total weight of the wagon loaded to capacity is 23 tons.
That's why tare weight is almost always shown on a goods vehicle, so the total deadweight of a train to be hauled can be calculated.
Post by Hatfield Shed »
A late friend had some coal traffic wagon cards from the 1960s, which would at that date most likely be conveyed in 16T vehicles, and as I recall it loads ranged from 7 tons some cwt, up to just shy of 10 tons.
cunningnLNER
GER J70 0-6-0T Tram
Many thanks to both of you - my ignorance was starting to annoy me ;-)
Neil
