New unopened 51L wagon kits
- LNER N2 0-6-2T
sold
- NZRedBaron
- H&BR Q10 0-8-0
Re: New unopened 51L wagon kits
Tell me, exactly what are these 51L kits that you speak of?
- LNER N2 0-6-2T
51L kits can be found here:
https://www.wizardmodels.ltd
But, they are white metal kits. In an ideal world that means one needs excellent soldering skills. White metal has a very low melting point, so ordinary soldering does not work. Although, it is possible to construct them using epoxy resin. But the latter is not recommended.
- LNER N2 0-6-2T
51L white metal wagon kits are easily assembled with Epoxy, I have several which have been constructed in that manner.
BTW Wizard have no wagon kits only parts, should you find a retailer with stock I would be delighted to hear about it?.
- LNER N2 0-6-2T
I suggest you take a look again at Wizard Models, they have a significant range of wagon kits many of which started life under Dan Pinnock D&S Models range
Dans range went mainly to Adrain Swain of ABS, a few passed to London Road Models but as far as I know none went to Wizard. With Adrians estate being sold off it's likely that some might end up there.Wolf of Badenoch wrote: ↑Thu Sep 10, 2020 7:22 pm I suggest you take a look again at Wizard Models, they have a significant range of wagon kits many of which started life under Dan Pinnock D&S Models range
A quick check Of Wizards site doesn't show either ABS or D&S as the origin of any kits.
The origin of some of the kits with D & S goes way further back, to the days when Dave Scott started the 51L range. If he sees this he may comment, if not I'll ask him about it on Saturday.
- LNER N2 0-6-2T
The original 51l range from David Scott became the David Geen range of wagons that was developed into a larger range. I spoke to David Scott some years back at Wakefield and understand that he bought a lot of the D&S range of predominantly NER wagons with a few others thrown in H&B stock.This range then took the 51L name And traded under that name until it was sold to one of the previous owners of the Wizard range that is now owned by Andrew Hartshorne.
The D&S range of GCR wagons is now with the GCR Society and the GNR and LNER wagons wagons went to ABS with Adrian reintroducing some of the GNR wagons under his brand.
- LNER N2 0-6-2T
If you purchase any of the NER wagons from Wizard the instructions are or certainly were until recently the same as those from D&S.Dave S wrote: ↑Thu Sep 10, 2020 8:49 pmDans range went mainly to Adrain Swain of ABS, a few passed to London Road Models but as far as I know none went to Wizard. With Adrians estate being sold off it's likely that some might end up there.Wolf of Badenoch wrote: ↑Thu Sep 10, 2020 7:22 pm I suggest you take a look again at Wizard Models, they have a significant range of wagon kits many of which started life under Dan Pinnock D&S Models range
No one said the ABS range went to Wizard ?
Why would the Wizard site show the origin of some of the wagon kits being D&S when that range had already become the second iteration of the 51L range before it was absorbed into the Wizard business ?
It seems I got it wrong. Dan never mentions 51L when he talks of where the range came from or went to, only the societies, LRM and ABS.jwealleans wrote: ↑Thu Sep 10, 2020 9:19 pm The origin of some of the kits with D & S goes way further back, to the days when Dave Scott started the 51L range.
