Finsbury Park Station - 1930's (before New Works Programme)
Re: Finsbury Park Station - 1930's (before New Works Program
I'm glad the images are of use. I took many more so if there are some details missing I may be able to find them on the others not included in the set.
StevieG, this is the plan I brought to the GNRS Spring Meeting, nice to see it is now of use!
I have been watching a number of threads on the Forum (southern GN based) over Christmas and it has been nice to put some box names to locations on the plan.
- LNER J94 0-6-0ST Austerity
Steve.
Well Steve you're absolutely brilliant. This is just the kind of information i need to make my scale drawings before putting everything into 3D. Cheers.The Green Engine wrote:Steve,
That's a gold mine of info. Thank you so much. Cheers. Matt
Dirk
When i study the map of Finsbury Park on the photo's of Steve one thing puzzles me.
I understand the 2 squares with crosses in them on platform 3&4 and on platform 5&6 which are the lifts from the platform to the milk traffic subway.
What i do not understand is the same sort of squares with crosses between the southern platform buildings and the stairs on platforms 1-6. Does anyone have a clue what they represent?
Dirk
Dirk,
I have viewed a number of other GNR Finsbury Park plans this morning and each show the object you describe as shown on my version. On one copy it shows a dotted line to the stairs and I would presume these were lift shafts, if not for the public for goods transfer? (The plan I photographed, which is in my possession, is slightly more detailed.)
The plans viewed were in relation to the underground works and widening of the lines and of the 1899/1902 to 1911 era. (The plans are included on the Great Northern Railway Society ( GNRS) Archive disks No's 2 and 6)
- GNR J52 0-6-0T
Evening All,
Here goes then... A draft track plan in need of refinement and a few compromises and space savers. Track is Peco streamline template.
Obviously running lines are down in number, and the plan has been compressed on both the down and the up side. At least one of the double slips is also a compromise and the coal yard has moved. I reckon that I have space for platforms of about 2m so I am very lucky to have the space. Each square on the grid is 10cm.
Once done, there will be a fiddle yard and allow for continuous running to satisfy my inner seven year old.
Tramway is a possibility and would run from the bottom right to top left, but will require the seven sisters road to be doglegged to suit. All pointers and ideas gratefully received. I have promised my wife this will be the last effort at woodwork so I really need to get it right this time.
Two questions.
1. Is the fly over possible (I think not) but would be a fantastic scenic break.
2. Could carriage sidings be added (I think so).
Thoughts appreciated.
Matt
Two questions.
Matt
- GNR J52 0-6-0T
Good Morning All,
Here is an updated track plan which I will stare at for a while to try and work out the possible problems and downfalls....
At the moment there is no cross over between up and down which is one point I need to give some thought to.
I am reasonably pleased with it and access and reach should be OK with some clever design.
As always, comments welcome.
Matt
Matt
- StevieG
You may well need a Down/Up crossover for practical purposes of your own Matt, but, for what it's worth, pre-1970s resignalling, and I'm fairly sure, as far back as at least the 1930s, the prototype had no such connection facility at main line level (one may well have existed in much earlier times). This facility being nearest available at, on the main line, Holloway (north; top of the bank from King's Cross) and Harringay, and alternatively on the Canonbury and 'Northern Heights' 'branches', at signal boxes Nos. 1 and 7 respectively.
IIRC, suburban ECS used the 'ramp' to access the Northern Heights branch to Finsbury Park No 7, were they ran round there trains then dropped back down to platform 1 or 2 then pushed there trains back in to coach sidings, or reversed across the bridge from FP No 7 to platforms 1 or 2 and then ran around there trains.
I know in diesel days when the Northern Heights branch had been closed , we used a dead end siding at Hornsey, to access Harringay flyover, so that we could get back to Finsbury Park CS.
- GNR J52 0-6-0T
Good evening all
Thanks for the replies. Fwiw the purpose of any crossover would be purely practical and I think, with some adjustment, that can be achieved outside of the scenic sections.
Pleased I think with the overall look and feel and the next stage will be to turn my attention to bench work.
Still some time for a few changes of mind before track goes down.
I hate carpentry!
Best
M
I hate carpentry!
Best
M
- GNR J52 0-6-0T
In displacement activity from biting the bullet and ordering wood, I have been working on some rolling stock, renumbers and a bit of research.
In the course of research I found these which are a fascinating insight:
https://www.flickr.com/photos/warsaw194 ... 005913574/
Best
M
Best
M
- GNR J52 0-6-0T
Evening All,
After a bit of procrastination, the first main frames are in place for the layout.
The underground will sit under the tramway with the LNER station at the top level. There will be some comprimises but I am hoping to catch the atmosphere well.
Comments welcome, but I should actually make the reach ok with a step.
Best wishes
Matt
Best wishes
Matt
- Attachments
- IMG_2117.jpeg (15.64 KiB) Viewed 7173 times
- IMG_2116.jpeg (20.75 KiB) Viewed 7173 times
- IMG_2120.jpeg (17.96 KiB) Viewed 7173 times
- StevieG
I see I missed picking up on one point when this was a fresh post, manna.manna, on Jan.19th 2014, wrote: " G'Day Gents
IIRC, suburban ECS used the 'ramp' to access the Northern Heights branch to Finsbury Park No 7, were they ran round there trains then dropped back down to platform 1 or 2 then pushed there trains back in to coach sidings, or reversed across the bridge from FP No 7 to platforms 1 or 2 and then ran around there trains. .... "
I think it must only have been 'reversed across the bridge...', as on no diagram I've ever seen for FP No.7, including an approx.1933 Notice for when the LNER resignalled from FP7 to Highgate with multi-aspect colour-lights and Track Circuit Block, has there been any points shown at No.7 other than the one Down-Up main crossover and the single-ended Down Branch/Up Carriage line, so there was no possibility of running-round there. Presumably once then down in the station, the trains were drawn forward into FP Carriage Sidings.?
- StevieG
What a collection of images! Thanks very much for providing that link.The Green Engine wrote:In displacement activity from biting the bullet and ordering wood, I have been working on some rolling stock, renumbers and a bit of research.
Best
M
- GNR J52 0-6-0T
A couple of new (poor quality pictures to give an idea of shape and progress.
The idea is to get the underground bedded in and then build upwards from there. I have used the Street level models kit for the Station although this is a draft copy just to get the tempting right.
Best
M
Best
M
- GNR J52 0-6-0T
Re: Finsbury Park Station - 1930's (before New Works Programme)
So while I move things along slowly, here is a proof of concept drawing for the station frontage which I am quite pleased with. The silhouette portrait featured in a recent thread may well be the answer I'm looking for for the windows.
