Ah, Paul, sheer poetry!!
But as regards the Mousa Models etched brass goods wagon, personally I think it's the wrong material for the job, and the etched line surrounding where the strapping should go is a no-no: it reduces the area to be bonded and when it's larger than the item to be soldered over it, well, you can see the result for yourself. All it needs is a short vertical dash which you can extend with a pencil to aid the location. Why make life more complicated, especially if in practice it's a poorer solution?
Last edited by 60117 Bois Roussel on Mon Jan 16, 2017 3:18 am, edited 1 time in total.
Finally getting on with my 4mm A3 'Felstead ' here is the first pics of the chassis build main parts cleaned up ready to go:
Excellent work, the tender is a joy.
Frames soldered together and bearings all lined up:
[/url]
[/url]
Latest Update; Chassis now has new RP25 Markits wheels and the main connecting rods fitted, after a brief flirtation with Markits new Stainless steel crank pins I have reverted back to Markits Super Deluxe brass ones which have worked a treat.
Cylinders and Brake gear now fitted, bit fiddly but got there in the end:
