Bachmann 2-4-2T
Bachmann 2-4-2T
I notice that Bachmann are releasing a L&Y 2-4-2T soon.
I feel that it is pretty close to a LNER F1/2. I think the F1/2's were kept on the west side of the Pennines, so if anyone modelling the CLC etc there is a new loco class for your layout. It would probably need a new chimney and possibly a new dome.
Re: Bachmann 2-4-2T
Would the chassis be of any use on one of the GE 2-4-2 ?
Re: Bachmann 2-4-2T
G'day all
I think the chassis would be too long for a Wordsell gobbler.
Re: Bachmann 2-4-2T
F8 ? I have taken some pics of the prototype model today which I will post later
Re: Bachmann 2-4-2T
I model the CLC so a conversion to an F1/2 has a great appeal for me.
Re: Bachmann 2-4-2T
I don't know much about the L&Y, but if the Bachmann 2-4-2T has a belpair firebox, it may just need the boiler mountings changing; a flowerpot chimney, a smaller dome and possibly different safety valves. If however, it has a round topped firebox, then pieces need to be made to convert the firebox. This would probably lead to a complete repaint, rather than merely removing and replacing the numbers and insignia.
Better still if Bachman produce a F1/2.
Re: Bachmann 2-4-2T
The F1/F2 possibility has not gone un-noticed. Other related ideas are already on my back-burner too....
- GNR J52 0-6-0T
Re: Bachmann 2-4-2T
Where were those pics taken? Great Pic!
- GER J70 0-6-0T Tram
Re: Bachmann 2-4-2T
Graeme,
I’ve bought a Bachmann 2-4-2 to convert into an F2, but I’m struggling to find a drawing to work off. I could base my efforts on the pictures in RCTS and Yeadon, but that would not be very accurate. Do you happen to know of a source for F2 drawings. I’ve checked Isinglass and they don’t list it.
Regard
Andy
Regard
Andy
My workbench thread: https://www.rmweb.co.uk/community/index ... don-works/
Re: Bachmann 2-4-2T
There is a drawing in the November 1969 Railway Modeller, according to this list. http://www.brmna.org/xref/locolner.htm
Re: Bachmann 2-4-2T
If that's a Charles Reddy drawing it might be quite a good one to use. I'm afraid I'm short of drawings of many of the pre-Robinson GCR loco classes. I've just had a quick look for a 2-4-2 and failed to spot anything. If I have a drawing it must be hiding quite effectively....
Re: Bachmann 2-4-2T
I'm pretty sure I have a copy of that drawing - I'll have a look when I get back from golf. I think they did all the main smaller GC tanks in that series.
Re: Bachmann 2-4-2T
Hi thegreenhowards
I have pm'd you a scan from Dec'69 RM. Drawing is by an MS Daniels.
Andrew Emmett
Andrew Emmett
Re: Bachmann 2-4-2T
Afternoon all
I now think the best way to make a GCR 2-4-2T is to use the SEF N5 kit. The front splashers are separate, and are easily omitted. A spring (for the front pony wheels) needs to be added.
There was a Cotswold kit for the F1, which occasionally cropps up, but I don't know the quality.
